Old 03-18-2013, 11:09 PM   #11
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Default Re: Need help for a newbie please
Originally Posted by Marco View Post
Also could somebody please explain what I'm looking at our car is a 92 camaro Z28 with a 3 speed automatic and a 305 how do I figure out what the natural class is by looking at this
CAMARO 1992
191 191 305 305 305 305 305 305 305 350 350
Man Only Auto Only Man Only Man Only Auto Only Auto Only
140hp 140hp 170hp 170hp 205hp 205hp 205hp 230hp 230hp 245hp 245hp
CAMARO 101.0
Coupe 2 Dr RS 5 Speed 3025 3025 3170 3170 3170 0 3170 0 0 0 0
W/4 Speed Auto 3080 3080 3269 3269 0 3269 3269 0 0 0 0
Convertible 2 Dr 5 Speed 3142 3142 3287 3287 3287 0 3287 0 0 0 0
W/4 Speed Auto 3197 3197 3389 3389 0 3389 3389 0 0 0 0
Coupe 2 Dr Z-28 5 Speed 0 0 0 0 0 0 0 3194 3194 0 0
W/4 Speed Auto 0 0 0 0 0 0 0 0 0 3321 3321
Convertible 2 Dr Z-28 5 Speed 0 0 0 0 0 0 0 3298 3298 0 0
W/4 Speed Auto 0 0 0 0 0 0 0 0 0 3425 3425
S/SS Factors 145 150 210 240 245 241 235 245 235 268 270
1.1.09 5.19.03 1.1.09 7.10.07 1.1.10 1.1.10
S/SS Factors w Replacement Heads 275
1.1.13
& = Dart # 10021070
On the left side of each Guide, you find the vehicle model descriptions, and across the top are the available engine, identified by cubic inch displacement and original, advertised horsepower rating. At the bottom of each column, you may find another number which represents the NHRA factored horsepower. This is the number used in determining classification (not the advertised), and some engines will have a different factored horsepower for Stock and Super Stock.
The numbers in the middle of the page are the power to weight factors for each model and engine combination, and identify which particular class a vehicle fits into. For instance, if the particular vehicle/engine combination you are looking at has a factor of 12.39 in Stock Eliminator, the vehicle fits in I/Stock, which according to the 2001 NHRA Rulebook, is for vehicles with a power to weight factor of between 12.00 and 12.49 pounds per horsepower.
as far as I see, to be a Z28 auto it would have to have a 350 245/268 which would make it a I/sa
shipping weight 3321 lbs div by factor hp268=12.39 = I/SA
weight of the car should be 12 x268 +170 for the driver= 3386 lbs
only the manual 5 speed Z28 came with a 305
the RS camaro came with 305 in a auto
shipping weight 3269 lbs div by factor hp 241=13.56=L/sa
weight the car should be 13.5 x241+170=3425 lbs
It may be running as a 89 iroc with 305 .with a factor of 13.46 K/SA .305/220/241 hp
hope this helps
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
Old 03-28-2013, 11:24 AM   #12
Marco
Liked 4 Times in 1 Post
Ok folks we went out and tested our new (to us) stocker last night at what I believe was J weight and was able to go as fast as 7.58 what does this number translate to in the 1/4 mile?
Marco is offline   Reply With Quote
Old 03-28-2013, 11:42 AM   #13
HR9121
HR9121's Avatar
Somewhere in the 11.80 range depending on a few variables but that's close.
James Williamson
W200 J/SA. SS/JA
Old 03-31-2013, 09:16 AM   #14
Marco
Thank you, This may be a stupid question but would it be reasonable to expect the car to run farther under the 1/4 mile index than the 1/8 mile index?
Old 03-31-2013, 12:52 PM   #15
jmcarter
jmcarter's Avatar
Liked 3,235 Times in 984 Posts
1.56 X the 1/8 time is the "official" formula, which depending on the variables is a good rule of thumb, think NHRA uses 1.6
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-31-2013, 01:02 PM   #16
BRINK
Liked 140 Times in 43 Posts
You might want to talk to Bruce Parsons. No one's any better with small block Chevys. He's fast and passes tech.
BRINK is offline   Reply With Quote
Old 04-04-2013, 09:29 PM   #17
gmjimk
Liked 3 Times in 1 Post
Mark with your genes the boy will be double tough. Good luck from an old friend. Jim Kern
gmjimk is offline   Reply With Quote
