Old 04-04-2013, 09:39 PM   #51
58 Chieftain
Arrow Re: Ramon Lowe 58 Pontiac
Does anyone here have any idea how much a 58 Chieftain weighed in at(race weight) back in the day?
I would really like to know what Ramon's car weighed.
I'm working on a 58 Chieftain that was raced back in the 60's, up through the early 70's when NHRA changed the stock class rules that bumped 10 year old(or older) cars out of stock class drag racing.
I'm hoping to have this back on the track within the next month.
This car competed at the first 3 Popular Hot Rodding Championships at US131 Dragway, Martin Michigan in 69,70,&71
Name:	58 Pontiac 004.jpg
ID:	18186   Click image for larger version
Name:	58 Pontiac 003.jpg
ID:	18187   Click image for larger version
Name:	58 Pontiac 009.jpg
58 Chieftain is offline   Reply With Quote
Old 04-04-2013, 09:47 PM   #52
Default Re: Ramon Lowe 58 Pontiac
Old 04-04-2013, 10:25 PM   #53
58 Chieftain
putting a 67 400 in the car with a 700R4 trans, back to the 4.30 Safe-T-Track rear.
Name:	58 pontiac 2-1-13 008.jpg
ID:	18189   Click image for larger version
Name:	58 pontiac 2-1-13 010.jpg
ID:	18190   Click image for larger version
Name:	58 pontiac 2-1-13 013.jpg
Name:	58 pontiac progress Jan 20 013.jpg
ID:	18192   Click image for larger version
Name:	58 headers and crossmember 014.jpg
ID:	18193   Click image for larger version
Name:	58 headers and crossmember 009.jpg
Name:	58 headers and crossmember 011.jpg
ID:	18195   Click image for larger version
ID:	18196   Click image for larger version
Old 04-05-2013, 12:03 AM   #54
FED 387
Liked 333 Times in 180 Posts
saw some numbers of curb weight @ 3385 or so and shipping weight @ like 3070--- do not know how accurate those numbers are might help give you an idea tho
Old 04-05-2013, 12:04 AM   #55
vic guilmino
Liked 56 Times in 21 Posts
i still have my 3x2s off of my 58 pontiac bonneville conv
Vic Guilmino 1129 STK
Old 04-05-2013, 08:30 AM   #56
Paul Ceasrine
Liked 10 Times in 10 Posts
In 1968,
Ramon Lowe was running in G/SA (11.00 to 11.49 Wt/Hp) with the 1958 Pontiac Chieftain.
370/338 HP 'Fuel Injection'
The Pontiac's 'Shipping Weight' was a minimum of #3718 lbs.
Later, in 1969 - the NHRA deemed the 370/338 HP 'Fuel Injection' combination illegal for use on this 1958 Model Pontiac.
Photo from March 1968, at the Hot Rod Magazine Championships, at Riverside International Raceway (California).
In 1969, Ramon Lowe was now running in 'I/SA', with a 58' Pontiac Chieftain and a different HP combination.
1969.....I/SA........( 11.50 - 11.99 Wt/Hp )
And in 1970, classed in 'J/SA'........( 11.50 to 11.99 Wt/Hp )
Chasing the...'J/SA'... NHRA National Record of...........12.90 @ 106.50 MPH
Old 08-01-2013, 09:53 PM   #57
Paul Ceasrine
Doc,
Jay Hamilton is running a 1958 Pontiac Bonneville Hardtop 'Sports Coupe' with
a 370/330 HP '3 x 2 Barrel'
Classed in H/SA {11.50 to 11.99 Wt/Hp} .......... {#3825 lbs. ~ 330 HP = 11.59 Wt/Hp}
In 1958, the Bonneville was available as a Hardtop 'Sports Coupe' or 'Convertible'.
The wheelbase was 122".
The body length = 211.7"
Shipping Weight = #3825 lbs.
The key item, is that the 1958 Bonneville's were 'fitted' with the powerful 'Star Chief' engine.
The Bonneville had the 'full -trim' package and exterior side moldings.
Available with;
Standard Engine
* 370 / 255 HP '4-Barrel'
* 370 / 285 HP '4-Barrel'
Factory Option Engine
* 370 / 300 HP '3 x 2 Barrel'
* 370 / 310 HP 'Fuel Injection'
Dealer Installed Option
* 370 / 315 HP '4-Barrel'
* 370 / 330 HP '3 x 2 Barrel'
Over-The-Counter Option
* 370 / 338 HP 'Fuel Injection'
The 'Tri-Power' option was only $100.
The 'Fuel Injection' option was $500
It also featured the 'Strato-Flight Hydra-Matic' 4-Speed Automatic with a 3.97 '1st-Speed' low-gear.
Standard Gear-Ratio's
* 3.23 {3-Speed Manual}
* 3.64 {Automatic}
Optional Gears {Dealer-Installed}
* 3.90
* 4.10
The Bonneville was a beast, and weighed in at 3785 bs.
Photo from March 1968 {Hot Rod Magazine Championships @ Riverside International Raceway}
Old 08-01-2013, 10:53 PM   #58
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Wow. More information please. This is really cool.
What FI did the Pontiac have?
Was the 370 cuin engine later became the 389 and later the 400?
D
Old 08-02-2013, 10:07 AM   #59
Paul Ceasrine
Dan,
I'm no expert, but the 370 Block {4.063" Bore x 3.563" Stroke} was a slightly different
animal than the longer-stroked 1959 and later Pontiac engines.
The 'Fuel Injection System' was built by Rochester, and was very problematic
on the street, as well as adding $500 cost to the Dealer Price of the car.
Only 500 or so of the 1958 Pontiac's were produced with the 'Fuel Injection' option.
Despite problems on the 'Street', the guys at the Drag Strip could really 'dial-in' the
'Fuel Injection' unit, and get those 370's to fly.
The 'high-performance' 370 had a 10.5-1 Compression-Ratio, and there were several
Camshaft units available.
Also 'High-Rate' Valve Springs were included with the more radical bumpstick,
as well as 1.65-to-1 Rocker Arms.
Pontiac provided the 'special' Camshafts and they had 'special codes'
*) "886"
*) McKellar #6, #7 and #10
By 1968, these engine combinations were heavily protested by the competition, and in
1969 NHRA deemed several of them as 'illegal options'.
Old 08-02-2013, 12:11 PM   #60
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
The Mckellar cams were solid lifter cams......and very radical in a street car.
I had one in my '58 Chieftan for a while but don't recall what number it was...
I also had a complete F.I. unit......
I removed it from a '58 SuperChief 4 dr hdtp......along with the fender emblems......The car was laying in a farmers field in Flemington N.J.
In 1969 or 1970 NHRA no longer allowed combinations that were not available as regular production line available and this knocked out dealer installed optional parts as well as many combos that were really never built at all......engine/trans combinations like hydro's in sedan deliveries.....and 4 speeds in cars that never came with them..just to name a few...
Rich Biebel
S/C 1479
Stock 147R
