Old 08-13-2007, 12:24 PM   #1
Joe Helms
Default Re: 12 bolt gear breaking problems....
Use billet caps and US GEAR (Strange) Pro gears, and go racing.Joe
Joe Helms is offline   Reply With Quote
Old 08-13-2007, 12:32 PM   #2
ericsz
who makes a good billet cap?
ericsz is offline   Reply With Quote
Old 08-13-2007, 01:54 PM   #3
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
I'd go back to.012 and easy out of the water!
Daran Summerton is offline   Reply With Quote
Old 08-13-2007, 02:35 PM   #4
Joe Helms
I used Mark Williams(part #58100) needs minor machining as I remember. I think Moser also makes them. I would spend money on the caps before I spent on the preload covers.
Old 08-13-2007, 02:42 PM   #5
Haywood
Eric,
For sure on the pro gears. I'm 3100 and a 404 with dot tires and using transbrake i made 20 passes and kaboom with the front wheels in the air. Even had the 12 bolt cover from JA that holds bearing caps in place. Teeth are to brittle and will break sooner then later.
Haywood is offline   Reply With Quote
Old 08-13-2007, 04:00 PM   #6
JDEMARZO
Wink Re: 12 bolt gear breaking problems....
Do not think you can use a street gear with a trans break, to much stress on the teeth, go right to a pro gear and it should not break. You could get by with a street gear if you were just foot braking.
Good luck
JDEMARZO is offline   Reply With Quote
Old 08-14-2007, 03:10 AM   #7
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: 12 bolt gear breaking problems....
Ericsz: I run a stick shift Camaro with a 12 bolt rear end. I can tell you for sure if my 12 bolt stands up to the loads I put on it, a 12 bold will wokk for you too. 7800 rpm starting line launch and so far no trauble. Pro gear is the way to go!
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
