Old 04-17-2013, 05:20 PM   #1
Randall Klein
Liked 316 Times in 67 Posts
Default Re: AMC 66-72 optional specs removed
Hey! whose the contact guy for some changes we'd like? yeah! swap out our 57 year old WCFB's for a couple of replacement little Holley's or AFB's (either one, don't care)
Also, if it takes about a half a year to correct it back, that's OK too, we'd be fast for awhile
Who do we petition? Thanks in advance
Old 04-17-2013, 07:43 PM   #2
Steve OB
Steve OB's Avatar
Send a message via Yahoo to Steve OB
Cannibalism????
Ed Fernandez
Default Re: Could a SC/360 Hornet be a viable combination for stock?
Hold on to your money till next year.Wouldn't want to throw good money at bad.That's all I'll say.
Former NHRA #1945
Former IHRA #1945
T/SA
Steve Obertanec
Steve OB is offline   Reply With Quote
Old 04-17-2013, 09:30 PM   #3
SSDiv6
I am not biased to any make or brand, nevertheless, the parts are catalog, over the counter items just like all other makes did at the time.
If you take a close look at the specs for many other makes, they also benefited of the same type of parts.
Is this some sort of prejudice on a car make that happens to be a minority in the classes?
How did the Chevy 283 got to use a 327 intake?
How do the Chevy 396/375 cam specs clear the piston dome without modification?
Ford engines using camshafts that were only available over the counter only?
C-4 bell housings that fit FE engines?
Mopar 273 with Edelbrock intakes; over the counter item?
Boss 351 with a Holley carb?
1967 Ford Fairlane 427/2x4 with an automatic?
The list can go on and on....
Are the other makes afraid of an AMC beating them in class?
Old 04-17-2013, 09:48 PM   #4
Liked 10,903 Times in 2,255 Posts
Put them all back to OEM spec. If you can't buy a plate for it, its a super stocker.
Old 04-18-2013, 10:09 AM   #5
ss wannabee
Liked 7 Times in 7 Posts
Is this a return to originality? If so...better hold on to your Powerglides...early guys...your 3-speed stick trans...
and Randall...your White Cast Four Barrells!
ss wannabee is offline   Reply With Quote
Old 04-18-2013, 12:28 PM   #6
Jim Kaekel
Liked 535 Times in 110 Posts
I agree 100%. Mine's got over 120,000 hard, Michigan miles on the odometer.
Jim Kaekel 3836 STK
Old 04-18-2013, 04:24 PM   #7
Liked 5,147 Times in 1,964 Posts
I don't want to get into a discussion as to whether these particular items are bogus or not,
but I have a feeling this is not the end of this discussion.
You would think NHRA would know that you can't just add parts or classes ,and then take them away, causing a monetary setback for a group of racers.
You would think they would know something about legal precedent by now.
I think this is a dangerous road for NHRA to go down, that could have repercussions towards other non-assembly line parts...or whole cars , for that matter.
Old 04-18-2013, 04:57 PM   #8
SSDiv6
You would think NHRA would know that you can't just add parts or classes ,and then take them away, causing monetary a setback for a group of racers.
Well said Mark!
Especially if the data was submitted by the manufacturer and not a racer.
Old 04-19-2013, 12:10 PM   #9
Todd Boyer
Liked 6 Times in 5 Posts
Forgive me, but what plate, Larry ?
Old 04-19-2013, 02:29 PM   #10
License plate.
