Old 04-29-2013, 02:27 PM   #1
Default Re: Danny Byrd
Originally Posted by Jeff Lee View Post
Isn't the 327/325 a hydraulic cam engine? 327/350 is mechanical cam. Not that the lifter spec matters anymore...
Jeff, I believe you are thinking of the Corvette 327/ 340, 365 and FI versions.
Old 04-29-2013, 09:16 PM   #2
Jim Parsons
Liked 197 Times in 32 Posts
Both engines use Hyd lifter, 275 HP has .399 lift and 350 HP has .447. The L-79 does get the new Quick Fuel carb if you want over the Holley.
The 1966 327/275 has a three carb option; Q-jet, AVS, and the small(er) Holley.
Correct, one bad little duce.. by the Byrd man,,,
Jim Parsons is offline   Reply With Quote
