Old 05-06-2013, 11:52 AM   #17
FED 387
Liked 333 Times in 180 Posts
Default Re: 327/300 carb CFM
Not sure of the carb specs that is being used with that particular combo but the smallest AFB is rated @400 CFM and they go up in size to 750 CFM while a WCFB is kinda rated @ 385 CFM for the smallest ones--- Found this a long time ago not sure how accurate it still is
AFB Carbs
CFM Venturi Diameter Bore Diameter
Primary Secondary Primary Secondary
400 1 1/8 1 1/4 1 7/16 1 7/16
500 1 3/16 1 1/4 1 7/16 1 11/16
575 1 1/4 1 9/16 1 9/16 1 11/16
625 1 3/16 1 9/16 1 7/16 1 11/16
750 1 7/16 1 9/16 1 11/16 1 11/16
ALL AVS CARBS
Primary & Secondary same size 750 CFM
Primary & Secondary different size 630 CFM
4GC CARBS
486 1 1/8 1 1/4 1 7/16 1 7/16
553 1 1/8 1 15/32 1 7/16 1 11/16
692 1 1/8 1 15/32 1 9/16 1 11/16
