View Poll Results: Double entering at National Opens
Yes .. entering 1 car in 2 categories the same day is fine 27 32.14%
No... one car per category is the way it should be. 57 67.86%
Voters: 84. You may not vote on this poll
Old 08-17-2007, 08:58 AM   #11
TS310C
Default Re: Double entering at National Opens
Originally Posted by Incognito Gecko View Post
Let's put it this way, you did not see many hoods up in the staging lanes. And seeing a car run 2 seconds under the class index they put on their window decals. No scales or fuel check which is fine since there were no heads up races even if two class cars were paired in eliminations.
If there are no heads up races then it is basically a bracket race. What difference does it make at that point?
TS310C is offline   Reply With Quote
