#11 | |
The number 5 (last ) main bearing was badly beat up on the front half. And that was the one web with no cracks. One other thing that was not normal was the rod bearings (1 run)were showing some wear at the ends. I remember with the hemi's we had to cut the rod bearings when we used a full radius fillet crank. The neon cranks are not full radius but undercut. So it should not be needed to trim the bearings. I don't have a clean neutral so when I lift it lugs down. But I don't think thats the problem. A lot of these neon's are making more power than me and don't seem to have these problems.
Art Leong 2095 SS |
#12 |
Liked 333 Times in 180 Posts
Art ---sent u a PM but I remembered who it is---Steve & Danny Rhoades from Frameworks in Glendale AZ---Telephone 623-869-9277--- might be able to help you---FED387
#13 | |
I have the crank up at my machinist right now. But all the counterweights are taken off except for the second one which was left for using the stock reluctor pickup (which I don't use anyway). It looked weird like it would be way out of balance, so I had them recheck the balance. And it checked fine. It is 8 pounds lighter than a stock crank. Block is not filled. Motor mounts are hard but not solid. In thinking, posting, and asking about this problem. I've come to the conclusion that I'm going to use a stock crank. The crank seems to be the one difference between my motor and many others that make more power and torque than me. I hope the 8 pounds of spinning weight dosen't slow me down much.
Art Leong 2095 SS |
#14 |
Liked 4 Times in 2 Posts
The only thing that I could see causing the block to fail is detonation, which would explain your bearing issues and your crank trigger failures. How much timing are you running? Mike
#15 |
Nothing up top shows any sign of detonation. I'm running the same timing that most N/A motors similar to mine are running.
Art Leong 2095 SS |
