Old 05-24-2013, 09:19 PM   #1
Lonnie Cox
Default how to tell a 750Qjet from a 800 Qjet
please tell me
My carb # is 17056502 do you know if this is a 750cfm ?
Lonnie Cox is offline   Reply With Quote
Old 05-24-2013, 09:39 PM   #2
Rob3105
Rob3105's Avatar
Default Re: how to tell a 750Qjet from a 800 Qjet
Look through the primary venturi and there is a ring/step on the outside of the bore. The 800 has a narrow ring and the 750 is wider. If you have both sitting side by side it is easier to tell. After you look at enough of them you will be able tell easily. This is the easiest way to tell quickly but you could measure the venturi as it is called out in the NHRA specs as 1.093 for a 750 cfm.
Rob Turkal
Rob3105 is offline   Reply With Quote
Old 05-24-2013, 09:41 PM   #3
Lonnie, On the 1.21 venturi carbs, the top screw that's inside the choke horn, will just about fall through between the venturi cluster (booster ring) and the outer wall. On the 1.09 it won't be close.
After studying that area, you'll be able to tell be the shape and curvature of the venturi wall.
Old 05-24-2013, 10:02 PM   #4
Lonnie Cox
Rob Turkal
Old 05-25-2013, 06:01 AM   #5
GTX JOHN
Liked 2,516 Times in 701 Posts
If you hold primaries open.......Is there not a Flat area on. 800 where it is
perfectly round on 750 outside walls?
BTW. I have a supply of Edelbrock Replacement Q jets all # and sizes.
