Old 06-10-2013, 03:59 PM   #1
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Default Re: 1970 nova 350/250
I think Joe DeMarzo runs that engine combo.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 06-12-2013, 12:12 PM   #2
Rusty Davenport
Liked 101 Times in 27 Posts
I would like to know the same information. I think the other option in the classification guide is 350-300 HP and the only difference is the heads and intake but I would guess the piston may be different too. Correct me if I am wrong but there were only two 350 combos available. I think DeMarzo has the 300 combo but I may be wrong. What would it take to make a 1969 from a 1970 car ????
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 06-12-2013, 12:35 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
I have 1969 Impala with same combo.
The Block is the same for 250, 255, 300.
Heads on the 250 and 255 are the same.
2v and 4v Manifolds interchange.
Heads on 300 are the smaller chamber 462, 492' castings, uses the same 4v manifold.
Old 06-12-2013, 01:57 PM   #4
HR9121
HR9121's Avatar
Wink Re: 1970 nova 350/250
Maybe that 1320racer guy will chime in, I'm sure he can tell you how its done.
James Williamson
W200 J/SA. SS/JA
Old 06-12-2013, 02:33 PM   #5
JRyan
Liked 112 Times in 31 Posts
Joe is running his as a 72 350-200. Which is the same as the 71 350-250 engine other then I believe the intake. He has run very well with the combination as has John Gray. John recently built a 396 Camaro but his Nova was very fast. There is also someone in division three running this combination in a Nova but his name is escaping me at the moment.
I also have the same combination. Mine is a pretty new car only have about 12 runs on it. I run mine as a 72 as well. So far I have run -.50. We are still working the bugs out. I also now have a metric in it and with some more tuning it should run -.70 -.80 on a normal day. Mine has decent pieces in it however, it is far from being state of the art with all the bells and whistles. I think it is a pretty good combination as a whole.
Rick
Old 06-12-2013, 02:38 PM   #6
mat H/SA
mat H/SA's Avatar
Liked 14 Times in 8 Posts
i run a 350/255 but mine is a 69 car works great,
a lot of other guys run the 350/255 in div 1, head # is 441
im not sure but the 300 is not the best out there
Demarzo is running the 350/200 as a 72
lots of great engine builders for this combo
i go to boucher's in Rowley mass, great to work with
mat H/SA is offline   Reply With Quote
Old 06-12-2013, 04:02 PM   #7
Joe DeMarzo
Liked 121 Times in 11 Posts
The 69 & 70 combo 350/250 is rated at 230, the 72 350 is also rated at 230 but the carb is smaller on the 72 vs the 69 & 70. If you want to run the 2 barrel you should build the 69 or 70 due to carb size. We may run the 2 barrel with a '70 combo in the fall.
The other difference is the 72 combo runs a dish piston as oppossed to flat with notch piston in 69 & 70. The valve, lift are basically the same in all years. I run the 72 because of my idol Johnny Gray, his nova set the standard for the 71 & 72 combo's.
Also the 71 & 72 camaro is the same combination for HP family (I think). Bruce Noland had a very fast 72 camaro before he build the vette.
Hope it helps.
Joe DeMarzo 1317 STK
