Old 06-19-2013, 03:16 PM   #1
Patrick Kelliher
Default Re: roller rockers
we haven't seen any significant performance changes. We just wanted some piece of mind after punching a few stamped steel ones. we just have some basic Harland Sharps .
Patrick Kelliher is offline   Reply With Quote
Old 06-20-2013, 10:14 AM   #2
njk53
We went with the Comp Cams Stainless rockers for two reasons, they are more durable than aluminum and they are rebuildable. They are a bit heavier than aluminum but aluminum fatigues and can break over time. I couldn't get the stories of aluminum rockers breaking and spilling roller bearings into the motor out of my head so, we went with the stainless for piece of mind.
I'm sure the better billet rockers don't have that problem as much as they once did.
Nelson Kowal
Stock 345
Old 06-20-2013, 10:53 AM   #3
Dave Ribeiro
Liked 56 Times in 27 Posts
Ron, you have a PM............
Dave Ribeiro 1033 STK
Old 06-20-2013, 11:37 AM   #4
R. Thorne
Liked 100 Times in 33 Posts
Dave, you have a pm.
R. Thorne is online now   Reply With Quote
Old 06-20-2013, 01:44 PM   #5
Bill Edgeworth
I have tried them all.
It’s interesting with the exact same peak lift my Holroyd ones are faster than my Harland-Sharp ones. Just a matter of the geometry of a stamped steel rocker vs. a roller rocker producing a different lift curve. I’ve never broken one of the Holroyd’s or Harland Sharp (knock on wood). I used to break the same punched steel ones all the time before I had Holroyd modify them for me. Only roller rockers I have ever broke were Crane on a big block Mopar. On that after changing to T&D I never had another problem.
Bill Edgeworth 6471 STK
Bill Edgeworth is offline   Reply With Quote
Old 06-20-2013, 02:48 PM   #6
R. Thorne
Thanks to all who replied here and PM's and to Randy Jr. at HarlandSharp. Bill, did the standard Harland Sharps (s6001) check the same max lift as the oems/Holroyd (ie same ratio or slightly higher) ? Anybody else notice any difference in their max lift after changing to roller rockers?Thanks, Ron.
Old 06-20-2013, 04:35 PM   #7
Bill Edgeworth
Harland Sharp produced higher lift, a shorter pushrod was required. Even the modified punched steel ones still flex.
