Old 06-28-2013, 02:12 PM   #1
mannymen
Liked 13 Times in 7 Posts
Default Re: SW Anti Roll bar for camaros and firebirds
Are the HRpartsNstuff rear bolt on sway bars legal in Stock E? Also, is it correct that GM A-Body aftermarket rear control arms are legal if the bottom bar is NON-Adjustable where the top control arm can be adjustable? Paul from HRparts has mentioned that they were NHRA Stock E legal as long as they bolt in only. No welding. Anyone using one?
See link below for an example
http://www.hrpartsandstuff.com/
N/A
mannymen is offline   Reply With Quote
Old 06-28-2013, 04:16 PM   #2
Jody Noble
I use one on a 65 chevelle (hr partsnstuff) works very well, nice piece and completely bolt on.
Jody Noble is offline   Reply With Quote
Old 06-28-2013, 06:07 PM   #3
Signman
Liked 269 Times in 99 Posts
There were some questions about the S&W roll bar a while back. Should contact them directly on how it was handled
All the bolt on sway bars are great but you really don't need it on a 3rd Gen. Camaro unless you wish to use it as a tuning aid. Which really is a band-aid approach, use air bags and weight.
Depending on which way you want to go there are several bolt on systems, they all work and you can do it yourself with some investigation and labor. If you want to run a sway bar the thinnest stock bar will work.
As Alf Wiebe said to me when doing my research: "The stock stuff isn't that bad."
