The standard Jerico ratio that you see is typically a 3.19 low. If you don't have adequate hook, maybe 3.08 or even less, but only if you are working around less then ideal set up like a street strip car or small tire combo that does not work well. Clutch plays a big role. 4.56? Low rpm engine or street strip? If you can't hook the low gear and adapt the ratios to compensate, get a gear set that is easier to upgrade. Make sure the forst gear set is 33/15 and work with Scott at Jerico to pick the rest. If you plan on ramping up the car to handle the more traditional race ratios, it makes a difference. If you do it right, you can then change only main drive gears to go to a 3.19. If you pick some weird ones, it gets expensive because you have to choose a whole set.
James Schaechter 3163 STK |
Liked 54 Times in 27 Posts
After a discussion with Scott on my fairly similar combination, I got 3.08, 1.93, 1.34 iirc.
#3 | |
http://www.jericoperformance.com/charts.htm
This lists the chart on gears. How much power and how much weight. What RPM do you plan on finishing at? The reason I ask is that your shift rpm doesn't seem to match your gear selection. Not saying you are wrong. Just need more info. If youhave the power and torque to run a lot of mph, then maybe you need a 2.90 something first gear. If not and you can't handle the rpm on the other end, maybe reconsider the shift rpm also?
#5 | |
The short tire at 134 answers the question. The detail in the last post is helpful. Definately not set up for best e t so that makes it pretty easy to choose. It depends on if you have any future plans to change the car. Sounds like the car has more than enough power to run 3.08 or even like a 2.93 or so. Only you have enough info to decide, but it would be good to discuss the ratios with Scott at Jerico so you don't pick something odd that is hard to change later. Good Luck!
Liked 3 Times in 1 Post
Seems to me you would be going the wrong way with the first gear. With that rear gear and small tire I would want a 3.19 way before a 2.93 or 3.08. Clutch setup might be tricky with not much ratio in the trans or rear end.
Ever call G-force? |
Picked up a T101A from G-force at super chevy. 2.98 1.91 1.33. 24/32 set.
