Liked 129 Times in 59 Posts
Question answered, Thanks!
Lew Silverman #2070 "The Wagon Master" N/SA Last edited by Lew Silverman; 07-18-2013 at 04:06 PM. Reason: Question answered! |
Jeff Lee 7494 D/S '70 AMX |
Liked 333 Times in 180 Posts
Guys--having trouble accessing NHRA site for "ACCEPTABLE PRODUCTS"---who other than Lokar is on the list for the header tethers?? Thanx FED 387
Liked 3,184 Times in 973 Posts
I couldn't find any exhaust tethers listed, not even a section for it so no Lokar product there. Suspect they are getting ready to update the product listings.
NHRA updated the list today...here's the collector tether info..
Manufacturer Part Number Lokar 1400009 Lokar 1401009 Collector Tethers.com Standard Collector Tethers.com Universal Kit BTW, I couldn't find any such domain name searching Collector Tethers but perhaps its a start up business just getting set up...somebody on here will probably know about the product and update us
Jim Carter 2340 Super Stock 2340 SST/2340 Stock Set another place at the table Last edited by jmcarter; 07-18-2013 at 10:22 AM. |
Liked 175 Times in 78 Posts
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
Liked 10 Times in 7 Posts
Am i reading the last page right?, I need a trans shield?
Liked 535 Times in 110 Posts
That's only a quick reference chart. Only when it is added into the Stock Eliminator section is when it becomes mandatory.
Jim Kaekel 3836 STK |
Chuck,
The Quick Reference chart lists Section 20 (General Regulations) Paragraph 2:14 Transmissions All vehicles running quicker than 10.99 seconds (*6.99) or faster than 135 mph (except some Stock and Super Stock classes as noted under Class Requirements) and using an automatic transmission must be equipped with a transmission shield meeting SFI Spec 4.1 and labeled accordingly. (“Blanket”-type shield, appropriately labeled as meeting SFI Spec 4.1, permitted.) All non-blanket-type shields must incorporate two (or one, per manufacturer’s instructions) 3/4 x 1/8-inch straps that bolt to the shield on each side and pass under the transmission pan, or transmission pan must be labeled as meeting SFI Spec 4.1. Permitted in all classes where an automatic transmission is used. There is no specific mention of a Automatic "transmission shield" in the Stock Class rules, Section 10A. Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
my experiennce in the past has been General regs override any of the class regulations UNLESS it specifically says something one way or the other!!! Better check to be sure ---The way I see it if your vehicle goes faster than X MPH or X ET you better have one
