Old 07-29-2013, 09:14 PM   #1
Monte Howard
Monte Howard's Avatar
Liked 71 Times in 23 Posts
Default Carb Spacer
Who makes a good 1" - 2" carb open plenum spacer? I am working on friends bracket car, don't know a lot about the motor. He bought this back halved s-10 and motor as a package. I do know its a 377 sbc .570 ish flat tappet cam. 270-280 @.50, aluminum heads that have no name on them. Nice open plenum Edelbrock intake, Holley 4150.
Not looking for any top secrets. Just want to buy a good carb spacer that works.
Thanks Monte.
Monte Howard 3209 STK, 3208 SS
Monte Howard is offline   Reply With Quote
Old 07-29-2013, 09:29 PM   #2
mr305
Liked 2 Times in 1 Post
Send a message via Yahoo to mr305
Default Re: Carb Spacer
Hvh makes a nice 4 hole I use a lot on dirt modified engines seems to average anywhere from 6-9 hp on the Dyno
Aaron Disinger
mr305 is offline   Reply With Quote
Old 07-29-2013, 09:40 PM   #3
Jeff Lee
Jeff Lee's Avatar
Comp Cams makes a really nice one with vibration dampener built in. Great part, makes power, not cheap!
Jeff Lee 7494 D/S '70 AMX
Old 07-29-2013, 09:49 PM   #4
pmrphil
Liked 348 Times in 152 Posts
X2 on the HVH spacer - they make a killer piece, 4 hole transitioning into an open, my own preference is the 2" one, we have seen 31hp on the dyno on one occasion with only the addition of the 2" spacer - might have been a bit too small of a plenum added to the change, but 31 is still 31.
Phil Molski
PMR Performance
S/C 1623
pmrphil is online now   Reply With Quote
Old 07-30-2013, 08:15 AM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Spacers are a trial and era part,I 've seen cases where they make 25,loses 25 ,or does nothing,it just depends on combo and how close plenum size is to what engine wants.
Mike Taylor 3601
Mike Taylor 3601 is online now   Reply With Quote
Old 07-30-2013, 09:10 AM   #6
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
x3 on the HVH Super Sucker.
Old 08-01-2013, 05:09 AM   #7
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
x4 on the HVH Super Sucker.
I picked up 8 hp over a 1" open with a 1" HVH....
Old 08-01-2013, 10:45 AM   #8
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
If it's a "super sucker type spacer aka blended spacer you want, the phenolic version available from Canton is a better piece than the plastic from hvh...
https://www.cantonracingproducts.com...CER-BLENDED-1/
That said, I have never seen any improvement on the time slip from any spacer on any car I've owned or tuned in the over 20 years I've been racing however I have used 1/2" phenolic or wood to isolate the carb from manifold heat.
Further, many bracket cars are running a manifold with too much plenum volume for optimum performance and the addition of a spacer just makes it worse.
