Liked 273 Times in 56 Posts
I've been plagued with Ed Fernandez's evil twin gremlin (sorry Ed, I couldn't resist) since the beginning of the season and have tried everything that I can think of to track it down but no luck. I was wondering if anyone in the New Jersey area knows of a place that has a chassis dyno that I can put the car on to see if something can be learned. Some of the shops have closed so if someone can steer me in the right direction, I would really appreciate it.
Ken Kopecky 1454 E/SA |
Julio at Cartek, Garwood NJ.
Ed Wright 4156 SS/JA |
Liked 795 Times in 210 Posts
Profab in Whitehouse Station.
"Pistol" Pete Dutko |
Liked 319 Times in 68 Posts
Ken , Div. one super stock racer Jeff Roell Danbury Chassis Dyno Danbury, CT. Not that far for you. Really knows his stuff has helped a lot of racers.
Lee Valentine 1661 STK |
Liked 126 Times in 61 Posts
Can Bill Trum here. Bobby Ida has a chassis dyno and he if right off Texas rd and rt9 in NJ
Liked 269 Times in 99 Posts
Jeff at Danbury Chassis Dyno. Some top cars roll off his dyno.
Kenny - If your car was a Top Fuel / Funny / or a Pro Stock there would only be one fix to the situation that you've been chasing all year - they would do it and so should you - tear out the wiring and redo it all .Then you can go and race again ............
Jack Matyas 1547 FS/C 2015 Camaro COPO # 62- 2012 Camaro Convertible COPO |
Liked 53 Times in 25 Posts
Jack he already did it.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Hi Jack. As Dennis indicated, I redid the wiring, checked all grounds and connections, replaced the entire ignition and fuel systems, new distributor, tach, shift light, batteries, carb, master battery cutoff switch, and retested the MSD setup twice. Still didn't fix the problem. I also checked the cam lift at the vavle, valve lash and static compression in the engine. All checked fine.
Ken |
Kenny -You have to do more than check them - they must be replaced - all of them or you'll never know ...............
