Old 08-05-2013, 08:57 AM   #1
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: battery charging between rounds?
I charge battery on my pure stocker to make up for running electric fans to cool between rounds.Usauly let fans cools radiator, then start for few seconds to move cool water from radiator to block,since don't have a electric water pump to circulate,can start and watch temp gauge come down then shutoff and cool radiator again.
Tar Heel do you have restrictor in place of thermostat?
Mike Taylor 3601
Old 08-05-2013, 10:14 AM   #2
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Which Optima battery is recommended for a car with an alternator? electric fuel pump, but belt driven cooling fan still. 70 Chevelle.
chris ok is offline   Reply With Quote
Old 08-05-2013, 01:21 PM   #3
Stock726
Liked 13 Times in 9 Posts
Optima Red Top.
Stock726 is offline   Reply With Quote
Old 08-05-2013, 07:53 PM   #4
Tar Heel
Guest
Posts: n/a
Mike Taylor 3601
No, it has a 160 thermostat in it. It's still a street car if you will. This summer we did the major changes to get it to run under ... gears, converter, cam, headers, wheels/tires, tune, etc. Now we can start tweaking and an electric water pump is next this winter and we'll do the plate then.
Scott
Old 08-05-2013, 09:22 PM   #5
Ed Wright
Ed Wright's Avatar
Scott
Scott, you might try (to go fast for heads-ups) keeping the engine over 180 deg, and icing the intake manifold. On my chassis dyno the all aluminium LS engines don't respond to lower coolant temps like a normal sbc, LT1, etc. They were more forgiving, making the same power between 180 & 200 deg. Guys at the local test n tunes at the track hot lap their cars without slowing down at all. I would try a 180 'stat if I were you.
Sure be worth testing.
Ed Wright 4156 SS/JA
Old 08-06-2013, 08:34 AM   #6
Mike Taylor 3601
Scott,
In Pure Stock no electric pumps or drives.
from page 47 2013 rule book
FAN,GENERATOR,WATER PUMP: Must be connected and operable at all times.Belts must be tight enough to drive equipment in a satisfactory manner and without excessive or noticable slippage. Must retain original factory produced fan.Stock size and material pulley must be retained. Water pump must remain stock. Electric fan may be added.
Mike Taylor 3601
Old 08-06-2013, 08:46 AM   #7
Mike Taylor 3601
Ed,
I was wondering would those LS's your talking about not responding to cooler water temp, could that be in the tuning? could they be rich and the higher temps lean them down to where they run better?
Mike Taylor 3601
Old 08-06-2013, 10:33 AM   #8
Ed Wright
Ed Wright's Avatar
Ed,
Mike Taylor 3601
Mike, it seems to be more aluminum blocks. I first noticed it when I went roundy-round dirt track racing in the '80s. At first around here we had iron block 350"s on gasoline, and most had Brodix heads. They liked to run cool just like my drag cars did. When we went to 410" full blown sprint cars with aluminum blocks I found on the dyno it didn't care for cold water. Liked to run between 180 and about 210. I attributed that to methanol fuel. Later when the LS1 came out, I saw the same thing with them on gasoline. I then thought it was something to do with aluminum blocks. Maybe I'm wrong, but tuning didn't make them like to run any colder. The GM factory computers correct for coolant temps. There is a table for P.E. (WOT) fueling corrections versus coolant temps as well as air temps. I tried tuning for max torque at 160, but if you warm them up the power came up. Guys seem to want to use 160 deg 'stats in those just like they always did with older engines. I usually just set their cooling fans to keep them around 180. I think he should test that on his car. Can't hurt, he may learn someting the others don't know.
Old 08-06-2013, 11:33 AM   #9
cad
cad's Avatar
Liked 91 Times in 51 Posts
For those that dont need to carry weight, why run the Optima battery @ 38lbs? $187 racer discount.
I've been running this battery in my car for about 7 years @ 26lbs.
http://www.jegs.com/i/Odyssey+Batter...PC925/10002/-1
$180 with racer discount at Jegs.
http://www.odysseybatteries.com/battery/pc925.htm
Oddyssey is also a military spec battery sold under a different packaging.
I put my Harley trickle charger on it during the week. It cranks my 12:1 385 very quickly.
Old 08-06-2013, 09:53 PM   #10
Tar Heel
Guest
Posts: n/a
Scott,
Mike Taylor 3601
What about the Meziere street pumps for the LS1 Mike? They bolt in the stock location, use the stock belt routing, etc. We already have electric fans on the C5 ... I'll just have to figure out how to turn them on manually between rounds.
Scott
