Old 01-12-2020, 04:43 PM   #1
jmracing
jmracing's Avatar
Default Re: 1973 Pontiac Firebird Formula 455-SD
Thanks Again,,,,,,,,, Mr. Run to Rund
Herlsow & Merlock from Scotch Plains, New Jersey
1973 Pontiac Firebrd Trans Am SD-455 {455/310 HP} re-factored to 345 HP.
1975 = E/SA
National Record set at ATCO {September 1975}
11.89 @ 112.50 MPH
My name is Jacques Marier from JMRACING from Montreal
July 16 / 2016 at Napierville Dragway at the NHRA National Open with my 1974 trans am SD455 PURE STOCK IHRA car legal at 3838 lbs
11.87 / 113mph qualify 1st (In Canada NHRA accept IHRA race car ) ( 2 time IHRA national record holder in D/PS 2003-2005)
jmracing is offline   Reply With Quote
Old 01-12-2020, 10:58 PM   #2
HP HUNTER
Liked 373 Times in 129 Posts
I've been trying to buy this for years, its sat behind a house since the 70s.
"I'am going to have restored"
Sure you are. And yes its a unmolested SD 455.
Old 12-16-2021, 12:38 PM   #3
oldskool
oldskool's Avatar
Liked 748 Times in 363 Posts
Seems that as I continue to search for Pontiac info I keep running across old threads I need to bring up.
While searching for info on the Herslow & Morlock '73 Trans Am, I ran across this thread. One of the posts says that the car set the E/SA nat record, in 1975.
But, here's why I bring this up. I have 3 pics of the car, before it was SD455 powered. It was still running G/SA, & had "455" on the shaker, which would indicate a D-port 455 engine. But, after they added the lettering, and it was still running G/SA, some of the lettering said the car was an NHRA Nat Rec Holder.
Therefore, does anybody here know when that G/SA record was set, & what the ET/mph was ?
The '73 SD455 Formula cars ran in D class, cause they were lighter than the T/A. John Clegg won D/S @ Indy '73, in his '73 SD455 Formy. But the '73 SD455 T/A's ran E class.
Any help finding info on the G/SA record for the H&M T/A would be appreciated.
EDIT: After I posted this, someone on a Pontiac site said NHRA put the '73 SD455 T/A's in G/SA, at 1st. IF this is true, then it's possible that the H&M '73 T/A WAS SD455 powered, when it was marked G/SA. IF this is so, then exactly when was the hp factor increased enuff to make the SD455 T/A run E/SA ? Any help with exact info on this will be appreciated !
Name:	1 - Truman vs H&M .jpg
ID:	61493   Click image for larger version
Name:	2 - Lettered still G-SA .jpg
ID:	61494   Click image for larger version
Name:	3 - CH H&M .jpg
Name:	4 - Mag Cover Car E-Stocker .jpg
Old 12-17-2021, 05:31 PM   #4
oldskool
oldskool's Avatar
A guy just posted this on a Pontiac forum.
"...Initially NHRA had the SD in G/SA..."
Does anybody here know if this is true ?
If it is, then the H&M T/A may have been running the SD455 engine, when it was marked G/SA.
But, John Clegg won D/S @ Indy '73, in his '73 SD455 Formy. So, if NHRA began the '73 season classing the SD455 T/A in G/SA, looks like they added hp to the SD455, in just a few months.
Can anybody here check this out, to find the exact dates in '73 when NHRA changed the hp factor on the SD455 combos ?
Could they have maybe begun the season using the factory net rating of 290hp, then increased it very early in the season ? Or ?
Would really love to know the exact timeline of all hp factor changes to the SD455 combos, during the '73 season.
I've posted that the H&M '73 T/A was running a D-port 455, when it was classed G/SA. But, it MAY have been SD455 powered, the whole time.
Anybody here know about this ?
Old 12-19-2021, 03:24 PM   #5
Terry Witzel
Terry Witzel's Avatar
Liked 50 Times in 28 Posts
Could you post a picture of your '74 trans am pure stocker?
