Liked 531 Times in 108 Posts
Here's something else to check. The front mounting point for the lower control arm can tear loose from the frame on occasion. As far as parts, Dick Miller Racing, HR Parts 'n' Stuff and QA1 has some of the best stuff available.
Jim Kaekel 3836 STK |
Liked 250 Times in 51 Posts
I think you are correct Jim. More then likely, the driver's side lower control arm front mount in the frame rail broke and let the arm slide forward.
I will know tonight. Thanks for the tip on the kits. "Christine" may live again! #5457 Curt Rees
Curt Rees 5457 SS |
If that's the case, HR has what they call "frame braces" that weld to the front lower control arm mounting point to strengthen it. I think they offer them for "A" and "G" bodies.
http://hrpartsandstuff.com/
The driver's side lower control arm front mount cracked at the welds allowing the rear end to move forward. The car is scheduled to go on the frame rack later this week to have the problem taken care of.
HR does make the needed braces for the "G" body mounts. Sounds like it is a common problem, especially on the Buick GN's. Thanks for the responses! "Christine" should be ready to run again shortly. Thanks #5457 Curt Rees
Curt Rees 5457 SS |
Liked 89 Times in 28 Posts
Also there are braces that connect the upper and lower front mounts.
Do you know who makes those Jody? Those are a solution also.
#5457 Curt Rees
Curt Rees 5457 SS |
Liked 17 Times in 14 Posts
Dave Outten 2222 S/SS/SST/SG/HR 2021 S 1968 SS 1969 SR 1966 1990 Bracket |
