Old 08-15-2013, 10:53 AM   #1
SSDiv6
Default Re: Another Rear Suspension Issue
Curt,
I noticed you are running a 12-Bolt rear end. Has the 12-Bolt been modified or did you just bolted the rear end from another car?
The upper mounts on a GM 12-Bolt have a different location to the rear ends used in G-Bodies.
There are kits available for the 12-Bolt swap on G-Bodies from various companies such as UMI Performance and others.
http://umiperformance.com/catalog/in...products_id=76
http://www.maliburacing.com/iceman/G...%20uppers.html
http://www.maliburacing.com/tech_rearend_swaps.html
http://www.baselinesuspensions.com/kits/chevy.htm
Old 08-15-2013, 12:01 PM   #2
Curt Rees
Liked 251 Times in 51 Posts
The 12 bolt was in the car when I purchased it. The only changes I did to it were the upper control arms and added a sway bar.
Everything installed the way it should. So any modifications were done before I bought it.
It may well have been an aftermarket housing. I did not ask the previous owner.
Thanks
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is offline   Reply With Quote
