Old 08-16-2013, 06:09 PM   #1
Mark Howes
Liked 80 Times in 28 Posts
Default Re: 30x10.5 radials on Stock suspension F-body?
I run the 10.5s on my SS car. To get the most out of them you should put them on a 12" rim which may not work for you. It is the same concept as running the 9s on the 10" rim. Best way to get all the tire.
Mark Howes is offline   Reply With Quote
Old 08-16-2013, 06:28 PM   #2
CJ Perry
CJ Perry's Avatar
I run my 9's on a 10" rim with really good luck. My current combo will 60 1.30 on kill on small tires. I'm sure it will hook with the 9's, I was just wanting a little more bite.
CJ Perry
9931
PCA-1
CJ Perry is offline   Reply With Quote
Old 08-16-2013, 06:53 PM   #3
Mark Howes
CJ. It's only what I seen with mine but I noticed a big difference in how the tire "wore" going from 10s to 12s. I run between 17 and 20 psi. With the 10s about an inch of tire on both sides was not getting "wear". Once I went to 12" rims even wear/stickiness post run right across the tire all the way to the sidewall.
Looking back I don't think I was using anymore tire on the track with the 10.5 tires then the 9" tires when mounted on 10" rims
That's on a SS/JA car that 60s in the low 1.30s. Your results may vary of course.
Good luck!
Old 08-16-2013, 06:57 PM   #4
CJ Perry
CJ Perry's Avatar
Thanks! I agree the 9" radial on a 10" rim is probably the same footprint as a 10.5 on a 10" rim.
I'm going to use my 9in tires until there worn out.
CJ Perry
9931
PCA-1
Old 08-16-2013, 11:00 PM   #5
countrypuppy4865
countrypuppy4865's Avatar
Liked 228 Times in 70 Posts
I am considering going yo 10.5 as well. However, I have been 9.70s in my firebird with 1.24 60 ft with 9" tires. I think they can easily handle 9.50s or faster. I run 22 lbs of air.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 08-17-2013, 12:14 AM   #6
Jim Hanig
Liked 99 Times in 49 Posts
C pup I ran both a couple of wks ago and the 9s where 3hun faster with the same 60 ft
Old 08-17-2013, 09:28 AM   #7
CJ Perry
CJ Perry's Avatar
Hahaha seems you got a little more motor than I do.
When I first started running radials, I fought traction until I learned how they work and what they like. I've never fought traction issues after I got it dialed in.
I'm sure I will have some data in the near future.
CJ Perry
9931
PCA-1
Old 08-17-2013, 11:31 PM   #8
TOP GUN
I have a set of those with lots of holes left. 150 can bring to jacksonville or darlington.mark young 9194272747
nitro joes TOP GUN 3 years straight
mark young
TOP GUN is offline   Reply With Quote
