Old 08-26-2013, 10:41 AM   #11
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Default Re: Anyone have a shift finger for Jerico?
Bobby I'll look in my spare parts. I've never broken one. Do you have a v gate shifter?
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 08-26-2013, 10:52 AM   #12
Ed Carpenter
Bobby I have one call me 512-517-8235. Ed
Ed Carpenter
Old 08-26-2013, 01:10 PM   #13
Rory McNeil
Originally Posted by Run to Rund View Post
I seem to remember a thread some months ago about a batch that were more prone to breakage. Scott at Jerico is the one to talk with. Also be sure that the shifter stops are carefully adjusted to lessen force on the finger and the fork.
I have 2 Jerico DR4s with Long V Gate shifters, and neither shifter has any stops.I`ve had 1 trans 12 years, the other about 5 years, never broke that piece.
NHRA 6390 STK
M/S 85 Mustang
Old 08-26-2013, 08:03 PM   #14
Bobby Fazio
Bobby Fazio's Avatar
I run stops and I checked them today, they never moved and we set them up on the bench to make sure they were perfect. This piece seems to break coming out of third and going into fourth so I don't think the stop has anything to do with it. I would think there is more stress coming out of gear then going into the next gear.
'65 Mustang SS/L & L/SA
Old 08-26-2013, 08:30 PM   #15
BILL TAYLOR
Liked 200 Times in 62 Posts
Hey Bobby, When you asked me about the shift finger at Maple Grove on Sunday and I said I never had that happen, I must have jinxed myself. In the semi's I had no 4th gear(went red anyway) but it seemed to stay in 3rd. Is that what happens when that thing fails? It tried it on the return road and it went into 4th. Sound familiar? Thanks, Bill.
BILL TAYLOR is offline   Reply With Quote
Old 08-26-2013, 11:23 PM   #16
Bobby Fazio
Hi Bill, sorry to hear. No that is not what happens with mine, it shears the piece that the shift arm is bolted to so the actual shift rod falls down and drags on the ground, the shifter then just floats back and forth in the 3-4 gate and nothing can happen because the rod is no longer attached to the trans anymore. Your issue sounds like the clutch could be getting hot in the late rounds causing it to be tougher to shift out of third. Or the rod was bound under heavy load, that used to happen with my old trans and on the return road would be fine. It would happen in later rounds when the clutch was gripping hard.
Old 08-27-2013, 09:49 PM   #17
BILL TAYLOR
Bobby, Thanks for your response. I didn't realize that part (I would call it the 3-4 shift fork) was breaking completely off. I assumed that it was doing something stupid inside like cracking which could be intermittant. I guess I'll have to pull it apart and look. Nothing worse than something that's only half broke. Can't really see how the clutch could cause this problem but anything is possible. Anybody got any ideas? When I find the problem I'll let you know. Bill Taylor Stk 1005.
Old 08-28-2013, 07:44 PM   #18
Bobby Fazio
Jerico doesn't ship again until Monday so if anyone has these fingers they would like to sell please let me know.
Old 08-28-2013, 09:30 PM   #19
BILL TAYLOR
Bobby, I assume you saw Ed Carpenters post!? I have your shop number. When is a good time to call? Thanks, Bill.
Old 08-30-2013, 08:39 AM   #20
Bobby Fazio
Yes thanks Bill, Ed shipped me one so big thanks to Ed.
