Old 08-28-2013, 02:17 PM   #11
joespanova
Liked 13 Times in 11 Posts
Default Re: 2 step & bad harmonics
There's a difference between the older 2 steps and the newer .
Analog to digital . I wouldn't do a burnout with a 2 step , but at launch RPM ( 7000 ) the newer digital boxes are very smooth.
Old 08-28-2013, 03:28 PM   #12
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
One thing I have noticed is the higher the rpm the smoother the 2 step gets or feels and sounds,I have used high side on starting line for long time have'nt had any problems ,but I am only on it from flash of first amber.
I agree completely with that article David Reher had in ND.
I say the lower the rpm of chip the harder it is on stuff
Mike Taylor 3601
Old 08-29-2013, 01:35 AM   #13
bigsixman
Liked 2 Times in 2 Posts
A buddy of mine just hurt his new 540" bbc by bouncing off the rev limiter. He broke a high quality roller timing chain and bits of the chain broke off and seized his oil pump which stripped the distributor gear and shut the motor down at the 60' mark on the strip. He was lucky that the timing chain did not completely break and bust up the valve train. He made several calls after this happened was told that this is common.
1969 camaro, pump gas 540"bbc, jerico
1967 camaro, pump gas efi 620", coan t-400
bigsixman is offline   Reply With Quote
