Old 09-16-2013, 08:15 PM   #9
John Nechiporchik
Liked 13 Times in 7 Posts
Default Re: Intermittent no start condition
Started it tonight....fired right up. Ran for a minute.....shut off.....tried again 5 times over the next 3 hours....no start.
FED....would you recommend another P/N coil or get another 8261?
Also, I recall previously that the fuel regulator seemed to stay near operating pressure for quite some time after the pump/engine was shut down. This regulator (Paxton) is immediately bleeding off instantly after the pump is shut off (engine NOT running) Drops to 15 psi (set at 45) in about 3 minutes.
Wondering if this is the problem?
John Nechiporchik is offline   Reply With Quote
