Old 09-18-2013, 12:03 PM   #1
Billy Baker
Liked 2 Times in 1 Post
Default 1998 Chevy Express Battery drain
My wary tow van has a 91 milliamp draw, which drains the battery every 2-3 days. I have tried everything i can think of. Hooked my multi tester up in parallel with the negative side of battery and cable.I installed a jumper wire in parallel also and waited 20 minutes for systems to go to sleep. I then started yanking fuses 1 at a time, including maxi fuses and relays in the under hood fuse block. Still no change.
I then stuck a new battery in it. Same 91 Milliamp draw. My last resort was to unplug the alternator ( not the hot wire) and it still has the same draw.
Any ideas?
Billy Baker 3187 G/SA
3586 SS/LA
Billy Baker is offline   Reply With Quote
Old 10-06-2013, 09:03 PM   #2
Jim Whitehead
Liked 150 Times in 41 Posts
Default Re: 1998 Chevy Express Battery drain
Hi Bill
Disconnect the Battery and put the positive and negative terminals together for 10 minutes. This will drain and discharge the capacitors in the ECM and BCM. When you hook up the battery negative terminal first, the system will reinitialize the modules. This is a common problem with GM vehicles
Jim Whitehead is offline   Reply With Quote
Old 10-07-2013, 12:42 PM   #3
Billy Baker
Thanks for the advice, Jim. I think my Multimeter was reading wrong, as it had a blown fuse.
3586 SS/LA
