Liked 20 Times in 12 Posts
You could experiment. Since you run at 43deg. Make a run at that timing. Then make a big change, 38 deg as a example. Then make a run. Look at your split times for both runs and see if it makes a difference. If you have a better back half at 38 but it runs the front half at 43deg best, then you are onto something. You can try this before investing in something. Just a thought.
#2 | |
What I was talking about is reducing timing on the start to kill power & help with traction. Some of the more powerful cars are cutting back timing at shift points. You would need a data logger to evaluate.
Jeff Lee 7494 D/S '70 AMX |
I've seen improvements in heavy low compression cars, where you need a lot of timing in 1st and 2nd then pull it back in high. But that was years ago when the rules weren't as liberal.
Liked 358 Times in 83 Posts
My next door neighbor is a high speed retard.
Liked 140 Times in 51 Posts
^^^ Hahahaha...!!! ^^^
Phil Hudlow 6678 (S/C, S/G, ET-PRO) |
