Liked 39 Times in 5 Posts
Car is very consistent and only needs a good driver to win rounds. Just won the Sunday Walla Walla National Open on 9/22/13.
305 flat top combo rated at 248hp (Camaro with the engine is rated at 263) CP pistons Greg Luneack Rings and crank Manley rods Bullet Cam Smith lifters Heads are from Heads Up but outdated, freshened by Terry Malm PAC beehive springs ATI converter Coan XLT 350 trans 2.70 low gear Moser lightweight spool and axles Spares include fresh short block (tenth and half slower than current short block), two intakes (aluminum and cast iron) Universal case T350 with 2.75 low gear (need freshened) Will run .55-65 under in bracket mode and heavy Hooks every time, you can run up to 38lbs in radials without fear of spinning the tires in a heads up round pictures under norm webber on autoimagery.com $13,500 Norm Webber 503-572-2799
Norm Webber |
