Old 10-02-2013, 09:12 AM   #21
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Rear Gear Question
Nelson: Just my opinion and you've been given plenty, but converter seems too tight, maybe 200-300 looser. I'm not sure what circumference tires you have, but they can be used to "tweak" the RPM's a bit, particularly when you're using a 2.75 trans. Don't forget that the wider gearing of the trans. makes the RPM's fall down more on the gear change. If you're running a 94" tire, a 92" tire will help get the RPM's up. A looser converter will help as well on the gear change.
Jim Kaekel 3836 STK
