Old 10-02-2013, 11:01 AM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Re: Intermittent no start condition
Bobby, After I got the car running, I tried to carefully reconstruct the test process that I followed and determined the following: The intermittent condition turned into a 100% no start condition as I was testing the various components. When I got to testing the injector connector, the homemade noid light ( a line lock light with two 6" leads with the correct terminals) .......I plugged one lead into the connector and the second lead momentarily touched the intake, resulting in a quick spark. I subsequently realized that this spark was the indicator that the fuse blew.
So, I'm pretty confident that I have isolated the root cause of the blown fuse.
Also, I believe isolating the ECU ground circuit from the stud with 6 ground leads stacke up (ran ground to - battery lug) took care of the intermittent condition. This was based on advice from an Accell service rep.
Thanks for your input.
John Nechiporchik is offline   Reply With Quote
Old 10-03-2013, 10:33 AM   #2
FED 387
Liked 333 Times in 180 Posts
jon --sent u a PM--FED 387
Old 10-03-2013, 02:06 PM   #3
John Nechiporchik
Got it.
