My thoughts are its probably not allowed based on what went down with the Mopar guys where the old cars could not run the aluminum center section.
Bill Edgeworth 6471 STK |
Liked 805 Times in 245 Posts
No aluminum cases allowed in Stock regardless of what gears are attached so that kills it right there.
Liked 719 Times in 220 Posts
How about the guy who puts a third member together for a Drag Pack with this stuff? It's already aluminum, which eliminates it from consideration in an older car,but I always interpreted the "no crossbreeding of parts"rule to mean engine parts. Let's face it, in Stock Eliminator today, rear ends, transmissions and converters are way more exotic than ever. Also the 3 speeds in the earlier cars is a further refinement that is another departure from the OEM configuration. I bet the 12 bolt gear set would be good for something of an ET reduction in a Drag Pack.
Liked 38 Times in 17 Posts
#5 | |
I may just call Mark Williams and see if that offset pinion carrier is still available. I like it over the Strange deal for a few reasons: 1. It's very stealthy 2. Could be used with things like a through bolt carrier for more rigidity 3. If the 12 bolt gear deal doesn't work out, you still have a carrier you can just put a 9" gear into |
