Liked 18 Times in 7 Posts
Thinking of changing from my Good turbo 350 to a Good Metric 200
about how much quicker would it be ? |
I think Chuck Norton might know, as well as who to have build it. Pretty sure that is what he used, and introduced me to his builder at Vegas a couple of years ago.
Ed Wright 4156 SS/JA |
Liked 56 Times in 27 Posts
Ken,
Talk to Jack Sepanek @ 570-457-6517 ( in Pa. ), he can help you out ... How much it will pick you up depends on your current combo .. That said, I think you will find at least a tenth or more .... He does lots of T-350 and M-200 for racers in Div. 1,2,3,4,5 ... Best part is he & Kattie are both racers.. You won't be Sorry, easy to work with & knows his stuff .... Remember the Metric comes with a 2.75 first gear, did your T-350 have a low first gear ? Good Luck,
Dave Ribeiro 1033 STK Last edited by Dave Ribeiro; 10-24-2013 at 05:35 PM. Reason: Adding info..... |
When I got my Metric from A-1 .07 was discussed. I did more than one change at the same time so not sure of actual numbers.
I do know this for sure it was worth a 60 pound savings from my t350 The 60 foots lowered ( different first gear ratio ) I used the same convertor between the two trans.
Dion Hildebrandt 6009 STK H/SA |
#5 | |
Scott McClay told me that on our big block car he would guess less than 0.03. His feelings were the less power you had, the bigger gain you see. Our TH350 stuff is all aluminum with gun drilled shafts and scalloped planetaries, so it is very light, only the ultra trick Coan stuff is lighter than what I have, in our TH350.
Alan Roehrich 212A G/S |
Liked 39 Times in 5 Posts
my coan xlt is about a tenth faster than the 200, you can feel the difference in the burn out box on how quickly the coan unit comes up to speed.
Norm Webber |
Liked 308 Times in 103 Posts
Back several years ago Randall Cambell had Johnathan (Bear) Tarrance build him 200 switched from 350 was in his truck w/4.3 picked up .35 in 1/8
Mike Taylor 3601 |
Well we tested,,,,,
THANK YOU SCOTT McCLAY !!!! I love the fact I can use my turbo converters with it, Last edited by KEN BUGAJ; 10-25-2013 at 02:58 PM. |
Scott is a great guy.
