signature test (name added)
Alex Cummings Newb |
Liked 251 Times in 125 Posts
The Astro A5 sounds like a good trans. I'm going to try one in my '87. It's been discussed a lot on The Corral.
#3 | |
i've looked at those as well. they seem to be stronger than the gforce t5 kits and to be fair the gforce trans are marketed as "street". it seems that they still have 3rd gear failures. If you end up going this route i'd love to hear any feedback. I'm going to start on the motor now and hope to have some cash together to deal with trans and clutch before spring. Before i pull the trigger i'll talk to the guys at gforce and Astro, and am leaning towards a Ram sintered clutch/alum flywheel setup (about $1500). Trans and clutch should be right aroud 4500 which is still "budget" compared to the the G5r approach.
Liked 62 Times in 21 Posts
Alex, while it's not the greatest you can make the T5 work, especially with a HO Mustang stocker. The key will be getting the clutch soft enough. Gear spacing is also an issue. Go to the NMRA forums and talk to the Coyote Stock and Factory Stock racers. The Coyote Stock racers are running 10.50s with T5s.
I ran 12 flat with a Liberty Proshifted T5 in a '93 Cobra K/S 15 years ago. Picked up a lot when I switched to a G Force GF5R, but the point is you can make the T5 work if you're on a tight budget. Good luck and have fun! |
Liked 14 Times in 11 Posts
One other item not mentioned IF your planning on running Stock Eliminator
is you will need to put door panel/headliner/back panels back in the car. If only running in brackets then no interior needed. May need to upgrade the roll bar to 8 point and a 5 point harness. Enjoy your project and just watch your expenses.
Phil Saran Parker, Colorado |
