Old 10-30-2013, 11:57 AM   #1
Jeff Teuton
Liked 325 Times in 50 Posts
Default Re: Looks like hp on Tuesday
Andrew, you got a 780 Holley which will flow more than a 1000 cfm throttle body. A 1000 cfm has 750 holes in the bottom. Looking at the specs on your motor, makes mine look like the truck motor it is derived froml 11 to one, same roller rockers I got, same cam, choice of 8 heads, some new manifold that nobody knows about, big carb (whichcfm for cfm will make more power-according to the manifold makers) and 325, all the 350's in 70 and 71 are suspect. If I had that I could run 9.70s and RJ could run 9.60's cause he is a better tuner. I guess you guys are in your right mind. I had a 35 Hudson Teraplane fastback with a V12 Hemi that got 10 off, and Sammy P. has gotten about 200 off that 427 thing he runs. RJ, nobody likes us old guys. I'm gonna complain to the AARP.
Jeff Teuton 4022 STK
Old 10-30-2013, 05:50 PM   #2
Liked 1,836 Times in 417 Posts
Jeff, unless I miss my guess, I'm pretty sure the 1000 cfm EFI throttle body does not have a big booster venturi hanging out in the middle of each of those 750 cfm Holley sized throttle bores. I'm pretty sure those are a considerable restriction.
Old 10-30-2013, 05:59 PM   #3
Chad Rhodes
It also flows only air, no fuel
Chad Rhodes 2113 I/SA
Old 10-30-2013, 06:13 PM   #4
Tom Turner
Alan; correct again! and if the booster is a restriction, how about the fuel molecule that the carb shares air space with that the throttle body does not? BTW; I'd love to have an engine in my stocker that makes 1.95 per inch that is NHRA factored at .95....should be pretty fast huh?
Tom Turner is offline   Reply With Quote
Old 10-30-2013, 06:01 PM   #5
Frank B.
Liked 51 Times in 25 Posts
I never sat in one of those new Mustangs but they must be hard to see out of to take a 1/2 second stripe on a heads up run.
Frank B. is offline   Reply With Quote
Old 10-30-2013, 06:18 PM   #6
RJ Sledge
Liked 288 Times in 90 Posts
Interesting question on the air flow.
We have done extensive testing comparing a 780 against the t/b and a carb with and without boosters. Would you believe that a carb without the boosters only flows a single digit increase compared to a 780 with the boosters?
. What really helps the 780cfm flow more air than the t/b is that the carb is nearly 3 times the height (counting the air horn) as compared to a 2 inch t/b. The carb, due to its" tunnel design", has the advantage of increased velocity compared to the t/b.
This helps in the atomization of the fuel and gives it a "heavy charge" and that results in almost a 30% increase in the flow/velocity for the 780 carb compared to a "dry" T/B.
Its really elementary physic's.
How'd that sound??
RJ
RJ Sledge is offline   Reply With Quote
Old 10-30-2013, 06:28 PM   #7
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
Not being a smart a.. RJ but with you switching to a Mustang doesn't that mean that you will be doing to older cars what you had done to you at Indy? Just saying ��
Your car is bad fast too!
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 10-30-2013, 06:29 PM   #8
RJ Sledge
or how about this?
Fuel droplets that are introduced into modified tunnel chambers (carb), actually give the air a friction fighting orgasmic attitude which steadily increases the air speed and flow capabilities of the fuel charge, as opposed to a dry air funnel effect as in the case of an t/b.
RJ
Old 10-30-2013, 06:36 PM   #9
RJ Sledge
Ed.....every chance I get!!
I figure that with the way I drive I will need all the advantages that I can get. Every time I beat an old car I will buy the driver supper and express my deepest apologies .
RJ
Old 10-30-2013, 06:58 PM   #10
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Actually, you're right. Visibility sucks due to the tiny little quarter window that gets worse when replaced with those louvers. I find the new Camaros to be even worse though.
kdanner is offline   Reply With Quote
