#11 |
Liked 1,032 Times in 368 Posts
I was told years ago to take the pipe plugs out of the back of the block, at the cam oil galleries and " center" the distributor to the 2 cast collars on the bottom of the distributor. This will put the gear of the distributor in the middle of the camshaft gear ,so it is centered...Wife's tale or the truth?... Alan. ?
Jeff Niceswanger 3740 SS Last edited by Jeff Niceswanger; 11-22-2013 at 11:51 AM. |
#12 |
Dang Bobby! You have five years on me. LOL
Ed Wright 4156 SS/JA |
#13 |
Liked 307 Times in 103 Posts
Jeff,
That method could get in ballpark, but oil galleys,oil groove on dist. are'nt really located that close,to where I would use them that way. Usaully I will place dist by checking the way the gears mesh together,I want them running where it meshes close to center on dist gear teeth and feel just a little bit of lash between gears. You can check pattern on gears with grease or gear marking compound if need to Mike Taylor 3601 Last edited by Mike Taylor 3601; 11-22-2013 at 02:08 PM. Reason: addtion |
#14 |
Make sure the bushings in the distributor aren't worn which will cause the shaft to wobble around and cause gear wear. We had the same problem with premature wear on the gear. In our case it was the gear itself..
Nelson Kowal Stock 345 |
#15 |
Liked 33 Times in 16 Posts
I may be misinformed, but I thought the bronze distributor gears were for roller cams only.
Rich Taylor I/SA - 321 |
#16 |
Bronze must be used on billet geared roller cams,but can also be used on cast and ductile iron cores.
Can't use cast or steel gear(regular) on billet though,there are rollers that have gears on them that can have regular gear ran on them,those cams can be identified,if you look @ cam you will see where on rear bearing journal and gear are made separately and then installed on cam. In the last few years they have came out with a few different gears materials,I have'nt tried any of them,I have just stuck with bronze,have good service with them so have'nt looked else where. In case some don't know MSD maybe some others also have gears that are available oversizes,that will reduce backlash if needed. Mike Taylor 3601 |
#17 |
the higher the pressure the more load on gear
