Old 11-26-2013, 01:27 AM   #1
Con6tY5efs
Default Re: Process for HP Review
Then and adjustment is made, up, down - or not.
Con6tY5efs is offline   Reply With Quote
Old 09-19-2014, 10:37 AM   #2
ALMACK
ALMACK's Avatar
Liked 373 Times in 131 Posts
After reading this thread and NHRA's procedure, I take it that the person requesting the change must have entered and raced the combo at least once at a national or divisional event ??
And...that the combo must not have made any passes any quicker than .6 seconds under the index ?
Am I correct ?
I know the national opens do not have the ahfs in place, so if a racer ran a combo ( that he wants a hp change on) at a National Open, it would not help him because those runs would not be included in the review process ?
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 09-22-2014, 09:45 AM   #3
Liked 10,960 Times in 2,260 Posts
Reread the AHFS rules. No review if combo goes one run -.85 under or two runs of -.65 under. Runs -.10 don't count, fastest run is used to raise or lower hp.
The system works, you have to read and understand the rules, its not easy but it works.
Like Smokey said " I can read 'em to y'a but........."
Old 09-22-2014, 10:40 AM   #4
Brian Oakes
Liked 439 Times in 116 Posts
Smile Re: Process for HP Review
Trust me, Larry has a degree in this department, LOL
Brian Oakes is offline   Reply With Quote
Old 09-22-2014, 12:39 PM   #5
ALMACK
ALMACK's Avatar
Thanks Larry.
So If a racer wanted a reduction in h.p. he needs to make all his runs (with that particular combo) in the .110-.150 under range ?
I/PS '95 Mustang GT
Old 09-22-2014, 02:36 PM   #6
Reread.
.101 to .165 under for 2.25% reduction and so forth.
If there is a lot of your type cars running, I would also recommend reading a couple of books on herding of cats!
The system works both ways, trust me on this. The only way it works is in the framework of the rules as written. As they say, "Almost correct is still wrong"
Old 09-22-2014, 04:36 PM   #7
Jack McCarthy
Liked 511 Times in 122 Posts
works like socks on a rooster...
captain jack
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
