I have a Lifan generator. That has a bad (leaking) priming button (bulb). I took it apart and it only has one fuel line going to it.
The generator is made in China so I might not be able to get parts for it. Other than that it runs fine. What can I use to replace it?
Art Leong 2095 SS |
Liked 333 Times in 180 Posts
Artie --Try Lifan Power USA they are located in Van Buren Arkansas 866-471-7464 8AM- 5PM M-F - that's customer service see where ya get--- FED 387
I've had that problem with my chainsaw for 5 years . I just plugged it and use ether
Liked 33 Times in 16 Posts
Check with any reputable small engine repair shop...chances are they may have something that will work.
Rich Taylor I/SA - 321 |
Thanks called and ordered the part.
Art Leong 2095 SS |
Got the part. Put it on . The generator started up easier than it ever has (cold in cool weather) and it was 50 degrees. I always had a fight with it at anything colder than 65 degrees or warmer. Easiest starting was in 90 degree weather.
Was always happy with the generator once it got started. Carries the load well, good on fuel, etc.
Art Leong 2095 SS |
