#11 |
Chip call me ..../I think i can help...
Danny Waters, Sr / 73 Duster "340" |
#12 |
Liked 13 Times in 9 Posts
>> It did fine the first 3 passes. 3rd rd I dropped rpm to 2200 and it did it again.
Oh, ok. I didn't get a chance to talk to you after the run. I figured you'd only give me an .022-.024 after being .000, so I was surprised at the .04. I figured maybe the polished rims blinded you. ![]()
#13 |
Liked 325 Times in 50 Posts
First make sure all the passages are clean. If you still have the power valve, take it out and plug the hole. Go up 2 or 3 on the jet. That is what made it go away on my Top Stock. Holley 4779
#14 |
Liked 290 Times in 83 Posts
Jeff,
The carb originally had the PV blocked. I like leaving between 2000 and 2400, at those RPMs it had a horrible idle. We put a PV in and rejetted. Carb idles geat now. Thanks Chip |
#15 |
Sounds like your idle passages might be blocked. I had one doing that. Didn't like to idle, but seemed ok @ wot. Quick fuel fixed it at the track. Idle passages were blocked amoung other things. Took a lot. After it was fixed, it made enough difference to bust 2 8/34 gears and 2 pro trans. I assume it is an out-the-box 4779?. Usually a stumble is lack of fuel. Just got to find it. On the T/STK 360 we ran 76 to 78 jets on all 4 corners and no pv. We left on a 2 step, but it would launch almost as well footbraking. No stumble and we ran 7 lbs pressure. Still run 7 lbs.
#16 |
Jeff after reading your last post. I'm going to check all the passages. It is an out of the box new 4779. We all know the quality of new parts these days.
Thanks Chip |
