Old 12-13-2013, 01:03 AM   #11
stocker396
stocker396's Avatar
Liked 58 Times in 16 Posts
Default Re: GM Stocker rear end
Yes! Danny Gracia Right in front of a drunkish Tom Compton. I was told that the "manufacturer" has final say so over the use of their product. If GM says no NHRA says NO! There were a couple of other tech and officials there too, this was last year. I think I made a little too much noise and logical sense to them. but since I was not wanting to upgrade to a 100k car my opinion mattered NOT!
stocker396 is offline   Reply With Quote
Old 12-13-2013, 02:14 AM   #12
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Originally Posted by Bob View Post
A copy and paste of the rule book means absolutely nothing. Once again, the rules apply to some and not others.
A prime example would be a red Olds stocker that recently moved from the west coast to the east coast. It has been through tech many times and always passes. I believe it just won a divisional as well. But it clearly has a narrowed rear axle and altered frame rails. There is no other G body car that sits as low to the ground and has the tire clearance this car does. How is that possible??
A simple check of the distance between the backing plates and between the wheel wells may shed some light on this. But NHRA NEVER checks these things. They must not own a tape measure.
I doubt they even care about bogus stuff like that. Otherwise they wouldn't allow even half the junk they do. So I say, stick the nine inch Ford in. IF they catch it, as for forgiveness.
A copy and paste of the rulebook means exactly what it reads. If a housing is narrower than specified it is clearly illegal for use...period.
Rich Taylor
I/SA - 321
Old 12-13-2013, 02:22 AM   #13
HandOverFist
Originally Posted by stocker396 View Post
Officially NOT I repeat NOT for use in ANYTHING except COPO cars. Was told that with EXTREME prejudice by GM officials AND NHRA tech when wanting to replace my 12 bolt. Huge debate on the floor at SEMA Went rounds explaining and arguing my case and was finally told"You want to use the new rear end? Buy a new car and get rid of your old one!"
GM officials have no say in the matter They submitted the new car to NHRA and NHRA allowed it in Stock which means they abide by the same rules as any other vehicle...I have never seen any separate rules governing COPO cars, have you? A flat refusal to allow the new housing would require NHRA to re-write the rulebook and put them on very shakey ground in their argument. Do you believe a swap of their current housing to a 12-bolt in the new car would be illegal?
Rich Taylor
I/SA - 321
Old 12-13-2013, 04:50 AM   #14
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
Originally Posted by njk53 View Post
The rear suspensions on the Chevrolet, Ford, and Chrysler factory racers are nowhere near stock configuration, which in my opinion these cars should be using the stock suspensions with the same approved modifications the older cars are allowed. Are the older stockers allowed to use the same technology as the factory built cars? I think not.
Not letting this one slide. COPO and Dragpak yes. But tell me what is nowhere near stock configuration about a CJ rear suspension, and what they are allowed to use that older cars are not?
kdanner is online now   Reply With Quote
Old 12-13-2013, 10:55 AM   #15
Run to Rund
Liked 54 Times in 27 Posts
The rule doesn't save the racers money; 12 bolt, Dana, and 9" cost similar money to build right. Nor does it make the car more "authentic" or "stock" since we see a lot of cars that only had 10 bolts, or 8.75", etc. running the bigger differentials. If it is OK to look under the hood and see a non-authentic aluminum water pump, that is a lot more obvious than a non authentic differential housing.
Oh, sorry, I was interjecting logic and that has little to do with the issue.
Old 12-13-2013, 11:02 AM   #16
gbur
If we can get tech involved here may help the case !!
gbur is offline   Reply With Quote
Old 12-13-2013, 01:08 PM   #17
Larry Fulton
Larry Fulton's Avatar
Rule book states - "Distance between backing plates may not be changed."...
Another "Stock Eliminator" rule that is totally ignored anymore...
there are lots of "bogus" examples out there if you just pay attention.
Larry Fulton
Larry Fulton is offline   Reply With Quote
Old 12-13-2013, 01:42 PM   #18
bigdaddy4026
bigdaddy4026's Avatar
Thumbs down Re: GM Stocker rear end
i was told the copo is a part # (no vin)there is no where that you can look up a part # for a gm copo rear end, thats what alows them to say older cars can't use them because its not a over the counter part sold by gm unless you bought a copo or a rolling chassis. i don't think you can even buy a 2012 camro and build a stocker with that rear end because it didn't come in any corperate car
as long as the kids are having fun thats all that matters!!!!
aaron knight
bigdaddy4026 is offline   Reply With Quote
Old 12-13-2013, 03:06 PM   #19
njk53
The COPO should have to use a 10 or a 12 bolt, the Dragpack cars a Dana 60 or an 83/4 Chrysler and the CobraJets a 9 inch or an 8.8 Ford unit. I am limited to a 10 or a 12 bolt, it should be the same for everyone. My point is the factory cars get to use all of the new technology components and the rest of us are stuck struggling with old technologies.
Nelson Kowal
Stock 345
Old 12-13-2013, 07:29 PM   #20
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
2013 COPO Camaro Service Parts
DESCRIPTION
427
396
350
Engine & Long Block Assemblies
Engine Assembly
17802825
19301608
19301609
Long Block Asm
19299607
19301614
19301615
Engine Components
Harnesses and Modules
Harness, engine control
19301111
19301111
19301111
Harness, engine control jumper
19301112
19301112
19301112
Harness, alternator excite
19301113
19301113
19301113
Module, engine control (Manual)
19302703
19302704
19302705
Module, engine control, (Auto)
19301200
19301610
19301611
Harness, Fuel injector wiring
19299611
19299611
19299611
Other Engine Components
Engine Block Asm
19213580
12623967
19213580
Rear Seal Retainer Bolts
11588723
11588723
11588723
exhaust manifold gaskets
12617944
12617944
12617944
Crank Shaft
19299608
19301270
19301559
Crank Shaft Main Cap Bolt
12556127
12556127
12556127
Crank Shft Rear Seal
89060436
89060436
89060436
Crank Sprocket
12556582
12556582
12556582
Crank Bolt
12557840
12557840
12557840
Crank Position Sensor
12585546
12585546
12585546
Bolt, crnkshf pos sensor
11515756
11515756
11515756
Stud, crk/shf brg cap
12560273
12560273
12560273
Bolt/screw, cr/shf brg cap
12560272
12560272
12560272
Camshaft
88958773
88958773
88958770
Camshaft Retainer Plate
12589016
12589016
12589016
Cam Retainer Bolts
11561455
11561455
11561455
Cam Position Sensor
12591720
12591720
12591720
Bolt, cam pos sensor
11588712
11588712
11588712
Cam Sprocket
12586481
12586481
12586481
Cam Gear Bolts
12556127
12556127
12556127
Rods - Connecting
17802817
19301271
17802816
Piston
17802821
19301556
19301558
Rings
17802822
19301557
17802822
Air induction tube
19299621
19299621
19299621
Map Sensor
12591290
12591290
12591290
Throttle Body
17802828
19301616
19301616
Injector
12598646
12576341
12576341
Throttle cable bracket
19299618
19299618
19299618
Fuel Rail Fittings
19301143
19301143
19301143
TPS (Throttle Position Sensor)
17123852
17123852
17123852
DAMPER ASM
19299313
19299313
19299313
Frt Seal
12585673
12585673
12585673
Frt Cover Gasket
12633904
12633904
12633904
Frt Cover
12600326
12600326
12600326
Front Cover Bolts
11515758
11515758
11515758
Timing Chain Tens kit
12581276
12581276
12581276
HEAD ASM - W/VALVES
17802818
12629063
12629063
HEAD ASM - Bare
17802804
19302061
19302061
Head Bolt
19258707
19258707
19258707
Head Bolt
12558840
12558840
12558840
INTAKE MANIFOLD KIT
17802810
19301195
19301195
Bolt, Intake manifold
12552344
12552344
12552344
Lifters
88958689
88958689
88958689
Lifter Guides
12595365
12595365
12595365
Bolt/screw, vlv lifter guide
12551163
12551163
12551163
Gasket, valley Cover
12610141
12610141
12610141
Valley Cover
19301146
19301146
19301146
Head Dowel
12570326
12570326
12570326
Coolant Temp Sensor
12608814
12608814
12608814
Intake Valve
12591644
12569427
12569427
Intake Valve Lash Cap
12596509
Not used
Not used
Valve Locks
10166345
10166345
10166345
Retainer, intake valve
17802819
17802819
17802819
Retainer, exhaust valve
17802819
12596508
12596508
Push Rods
12593344
19301617
19301617
Intake Rocker Arms
12579615
12569167
12569167
Exhaust Rocker Arms
12579617
10214664
10214664
Rocker Arm Bolts
11588791
12560961
12560961
Valve Cover
19301147
19301147
19301147
Valve Cover Bolts
12577215
12577215
12577215
Valve cover breather cap
19299619
19299619
19299619
Oil Pan
12640746
12640746
12640746
Oil Pan Gasket
12612350
12612350
12612350
Oil Pan Bolts - Short
11515758
11515758
11515758
Oil Pan Bolts - Long
12554990
12554490
12554490
Oil Filter
89017524
89017524
89017524
Windage Tray
12611129
12611129
12611129
Windage Tray Nuts
11609746
11609746
11609746
Pick up Tube
19301149
19301149
19301149
Pick up Tube Gasket
12584922
12584922
12584922
Nut, Pick up Tube
11609746
11600746
11600746
Bolt, Pick up Tube
11516521
11516521
11516521
Oil Pump
19301144
19301144
19301144
Oil Pump Bolts
11515758
11515758
11515758
plug, eng blk oil gal
9427693
9427693
9427693
Oil Pressure Sensor
12621234
12621234
12621234
Oil Dipstick tube
19301148
19301148
19301148
O-ring, Oil dipstick tube
24504031
24504031
24504031
Bolt/screw, oil dipstick tube
11588736
11588736
11588736
Other Components
Alternator
88864377
88864377
88864377
Mount kit, Alternator
19299546
19299546
19299546
Coil, ignition
12611424
12611424
12611424
stud, coil mtg bracket
12554211
12554211
12554211
Brkt, ign. Coil mtg
12580353
12580353
12580353
bolt/screw, ignition coil to bracket
11516424
11516424
11516424
wire asm, spk plug
89018057
89018057
89018057
sheild, spk plg wire
15336959
15336959
15336959
pipe asm, eng cool air bl
12602544
12602544
12602544
Body In White (BIW)
19243374
2013 COPO Graphics
Graphics Package - CHEVY RACING BLUE
23162259
Graphics Package - WHITE
23162260
Graphics Package - FLAT BLACK
23162261
Graphics Package - INFERNO ORANGE
23162262
This is a list of the only parts that are available over the counter for the COPO
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
