Liked 33 Times in 16 Posts
Beginning to look like they just want to transition everyone over to Stock for convenience.
Rich Taylor I/SA - 321 |
Crate motors are now built motors, nothing "crate" or "pure" about them anymore, right?
Ed Wright 4156 SS/JA |
Guest
Posts: n/a
Good point. Like everything else it started out simple and then gets out of hand (and expensive!). Top Stock is another example ... Not that it matters to many folks but this will end Pure Stock I believe.
Liked 405 Times in 158 Posts
"good controversy" is the point to take from all of this. IHRA (it appears) wanted to speed up or simplify tech and came out with a rule. The racers on here generated 6 pages of controversy in a few days. IHRA is going to reconvene in the new year and revisit the decision.
I agree, that's GOOD controversy! IHRA is actually listening and responding to the needs or wishes of the racers! The other positive note I take from this is the sanctioning body gave a "freebee" to the racers and they declined knowing it wasn't in the best interest of the class, even if it would of been in their own personal best interest to accept it. Dan Fahey, thanks for running point on this and being the un-elected liason between IHRA and the Pure Stock ranks. |
#5 | |
Liked 373 Times in 131 Posts
Thanks Dan
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
Liked 319 Times in 108 Posts
I don't think this will be reversed,it's more of issue of making it even for all,there are alot of cars that specs for duration/overlap,and spring are near impossible to get hold of.
My opinion is this is'nt big issue IF and I repeat IF cam,spring is only change,what I'm saying is keep it restricted on lifters,no tool steel,no ceramic, rocker stud like it is original size. Also keep it like ''Ex Techman" Terry Bell told me years ago when I was building my car and called him one night,I asked if having fittings on headers for thermcouples on dyno was OK Terry told me, Don't show with a pure stocker with acid heads and lifter bushed block. I think if all the parts that follow the duration and spring are not allowed then it will be OK. even though this could be the straw that breaks the camel's back for my car,as is engine is super reliable,valvetrain does require a little but is still reliable,with cam and spring change my valvetrain will be as reliable as now maybe a little better,because would be better able to control valve with added pressure,but bottom end could become weak link,with added rpm,will be pushing rods to edge. My car has right cam springs now so I'm good like it is,if rule sticks may just change spring and leave cam alone,I know just spring would make mine faster. Don't want pure stock to become muffled stocker. Mike Taylor 3601 |
Liked 51 Times in 3 Posts
Does IHRA actually check spring pressures in tech with a pure stocker?? If so I haven't seen it.
Keep cam and springs OEM. Random ck of a few springs no big issue. IHRA should require everyone(not some to photo part # off factory cam and submit via notorized copy. No wasted time on techs behalf
NHRA ruined the original Super Modified classes the same way after killing Modified Eliminator.
