Old 12-20-2013, 03:49 PM   #1
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Default Re: Quick time bellhousing
Steel here.
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
Old 12-20-2013, 04:19 PM   #2
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Is the Browell alum legal for stock?
Bill Diehl is offline   Reply With Quote
Old 12-20-2013, 08:01 PM   #3
terry1
Liked 24 Times in 13 Posts
Wink Re: Quick time bellhousing
What I found interesting was that the aluminum bell by Browell has a SFI 6.1 rating good for 5 years.I believe the Quick Time bell is good for 2 years.I could be wrong.
As far as the aluminum not legal for stock eliminator, this I don't know.
terry1 is offline   Reply With Quote
Old 12-20-2013, 10:37 PM   #4
boostedf22c
boostedf22c's Avatar
The rules for Stock read
"Steel flywheel shield meeting SFI Spec 6.1 or 9.1 mandatory on all V8 cars with a clutch. Flywheel shield cannot be modified for clutch adjustment and/or cooling holes. "
Then is says to see general regulations where it states
"The use of aluminum bell housing is permitted in all categories and applications. Aluminum bell housing must meet SFI specs. and no modifications to the as-manufactured design are permitted."
Carey Bales
316D DD/AT
www.racetactics.net
boostedf22c is offline   Reply With Quote
Old 12-21-2013, 08:35 AM   #5
tj310
I always found it odd that that the only hole they want you to have would direct all shrapnel right at your feet . Seems to me it would be safer for the driver if the bottom was opened ? ---Trevor
