Old 12-22-2013, 01:21 PM   #1
Painter
Liked 162 Times in 45 Posts
Default Re: Tires for your enclosed trailer ?
If you are ordering a new trailer the manufacturer should be able to put what you want on it. If they won't it makes me wonder how customer oriented they are and might change my mind on who to buy a trailer.
Painter is offline   Reply With Quote
Old 12-22-2013, 01:34 PM   #2
Run to Rund
Liked 54 Times in 27 Posts
If you ask for 16" the trailer will sit higher, the wheel wells inside may be taller, and they may use higher gvw axles. If the standard setup is 10k gvw, they might increase trailer gvw which makes you commercial in some states. If the loaded trailer won't exceed 8k, you may be fine with a 10k setup. If you bring the contents of your garage, etc. and want over 10k GVW, you may want to look up the DOT regs. for each state you visit.
