Old 01-05-2014, 12:24 PM   #1
FINESPLINE
FINESPLINE's Avatar
Default Re: Econo Modified
Originally Posted by randy wilson View Post
Well, if true, all GM cars in SS\CS prepare to change heads. For a small update price of, say $13,000 to $18,000 dollars with intakes, heads, valves, pistons, cams, etc. And then get ready for the next step. Allowing aluminum heads in. Then for the small fee of $15,000 you can compete again! Ain't it grand! Should work out REAL GOOD!!!
Makes you want to think about a spec engine with manual trans. Pick the body style and lbs/ci . EVERYONE who drives a stick knows the answer is in the can.
FINESPLINE is offline   Reply With Quote
Old 01-05-2014, 12:36 PM   #2
FINESPLINE
FINESPLINE's Avatar
Randy, If you really would like to keep it OLD SCHOOL and keep the word econo in this class, keep the the factory valve angles ( ie sbc 23 degree ). Inline wedge head only.
Old 01-05-2014, 12:52 PM   #3
randy wilson
Liked 22 Times in 22 Posts
ALL spec heads are factory valve angle. Chevy, 23 degree, Ford, 20 degree, Mopar, 18 degree. Already been handled. You do know we are saying a single disc clutch, min. diameter at 10.5 inch, and NO computers. The right clutch, pressure plate, and fylwheel will be the key. There would be no counter wts. allowed. Clutch would be required to be engaged on ALL shifts. Just saying.
don,t have one
Old 01-05-2014, 01:03 PM   #4
FINESPLINE
FINESPLINE's Avatar
All right, was not sure about clutchless trans and clutch setup. How about wheelbase limitations and finalizing a lbs/ ci. Starting to think of an old C/SM car !
Old 01-05-2014, 01:13 PM   #5
randy wilson
Ain't got that far yet, and actually ain't qualified to make the call on wheel base. Way over my pay grade! Ha!
don,t have one
