Liked 33 Times in 17 Posts
Matt,
Check out Howe Racing Enterprises. That have extended ball joints that go up to .9 long. |
Liked 799 Times in 236 Posts
Mat, I went with Energy Suspension urethane control arm bushings, Moog #K5250 offset control arm shafts and standard Moog replacement ball joints.
Afco and ProForged make low friction extended upper ball joints. QA-1 has standard length low friction ball joints that can be serviced. -Al
"That'll never work....." |
Liked 319 Times in 82 Posts
Afco steel bushings and there low friction ball joints, the Afco tops can be ordered .5 longer.
Liked 54 Times in 25 Posts
I just did what J&S posted and it made my car totally different! It was an easy install, car has a ton of front end travel now and drives like a dream
Liked 14 Times in 8 Posts
Thanks for the help guys!
Liked 5 Times in 3 Posts
Are the replacement bushings roller bearing or something like that ? When you say steel bushings does this mean its steel to steel ,no bushing material ? The longer Ball joints are for reducing camber change? thanks
The global west bushings are aluminum and derlin I believe and the Afco's are solid steel with grease fittings.
