Old 01-18-2014, 02:06 AM   #1
Adger Smith
Liked 880 Times in 311 Posts
Default Re: Please Read "Batteries discharged while sitting" ?
Google this: natural battery discharge
Start reading any or all of the links.
We have had many discussions on an Air Craft forum I frequent about this same issue. It is very common in aircraft because most general aviation planes sit for long periods of time without use. Sounds like some of our race cars, too.
I keep a battery tender on my plane & race car. I also do frequent checks on the battery condition. I had one battery tender go nuts and over charged a perfectly good race car battery. the guy at Wal Mart said he had never seen a battery with the plates burned/melted away. I also put the battterys on a bench, not in the car. I keep them away from anything that can burn. Plug the tender into a power strip. Fred Henson had one short out and burned his car and shop up.
Adger Smith (Former SS)
Old 01-18-2014, 09:12 AM   #2
FrankChastain
Location: Trussville, Alabama-Originally from Vidalia,GA
Anyone ever heard of stories of setting batteries on cement? What it does to them and so on.....FrankChastain
FrankChastain is offline   Reply With Quote
Old 01-18-2014, 09:16 AM   #3
Chad Rhodes
they are just that, stories
Chad Rhodes 2113 I/SA
Old 01-18-2014, 10:42 AM   #4
Liked 1,831 Times in 415 Posts
Actually Chad, a battery sitting on concrete that goes through considerable temperature changes will discharge because water condensation on the battery allows current to flow across the battery. Any water that is not perfectly free of all purities will conduct electricity, and water that condenses on a battery isn't pure. It does not always happen, but in climates where the temperature changes 20-30 degrees in a day or so, it can happen.
Beware of battery tenders and trickle chargers. I strongly suggest they not be left on batteries that will be unattended for any real length of time. While it is very rare, there have been instances of various factors causing even very low current chargers shorting out and causing fires. You'll be much safer if you just connect a charger set on 2 to 10 amps and charge your batteries for a few hours once or twice a month or so while you're around, and that will be enough of a regular charge to maintain battery life at acceptable levels. Charge your batteries while you'll be around where ever the batteries are, maybe throw the charger on when you get home for the weekend and can look in every so often, and take it off before you call it quits Sunday evening. It could prevent a tragic and catastrophic loss.
Old 01-18-2014, 10:57 AM   #5
Todd Hoven
Guest
Posts: n/a
Batteries were made with a carbon case a long time ago, the carbon would act as a conductor with the cement and produce a slow discharge. When the cases were produced with a plastic case some time 50+ years ago this issue went away
What ever its worth, I live in the Northeast. We have cold winters that last for 3 to 5 months. When a battery is subjected to cold for long periods of time without starting or maintenance, the can discharge over time. The good batteries can handle this better then the cheap ones. I have run Delco's, Odyssey, and now Optima in my 2 cars. One practice I started was to pull the battery out of the car and store it in the basement, and then use a tender on it here and there during storage. I think keeping it out of the extreme cold of the winter and simple charging maintenance goes a long way to a battery lasting. My Delco lasted until I changed to an Odyssey, ( for weight ) that was 3 years racing and 5 years in my friends street car. The Odyssey lasted 6 years, and went with my GTO when I sold it, and was used after for a year or so.
I now have a Red Top in my Firebird going on 3 years. Not saying my method is the end all be all, but I've had good results.
Old 01-18-2014, 10:58 AM   #6
Rick Schilling
Liked 14 Times in 10 Posts
True. Have proven it. Makes no difference.
I will say however, at least in my experience, I've had little to no luck with the Exide brand beginning with the Juice Box batteries back in the 70's. Have never been able get decent life out of any of them.
Could just be me but I don't think so.
Rick Schilling is offline   Reply With Quote
Old 01-18-2014, 11:17 AM   #7
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Sure batteries will discharge while sitting but like most everything else, you get what you pay for. IMO optima batteries are junk, tried a red top back around 2006 in my Chevelle and it didn't make a month before failing to turn over my engine when I was called to the lanes and it was charged with the correct AGM charger. Went back to the same AC Delco that I've been using since the early 90's with out issue or failure and I've never used a battery tender nor remove the battery(s) from my car in the off season. Same batteries in my Firebird since buying it and I will have no problem starting the engine in late February when I take it out of the trailer to ready it for the season. BTW, same batteries in my tow vehicle too.
Old 01-18-2014, 11:32 AM   #8
brent flynn
brent flynn's Avatar
1320... I have 2 Optima red top batteries...one has been in use since 2005, sits out in the garage every winter( im lazy apparently..hehe) , and still continues to fire up a 455 with 11:1...i charge them at the track, as well as at home, before i load car into the trailer. The other battery was purchased Christmas '05...It sat a couple years, then i got it...Its in my Bird and turns over a 12:1 455, with no problems. You must have gotten a bad one. I dont even have a mega amp alternator on either car. Just the standard Delco deal...i think they are 65 amps. I wouldnt hesitate to buy another one, and most likely will, this year, so i will have a back up. I run one battery in each car. Its a PITA to have to pull one out of a tow vehicle, if needed...hehe
Old 01-18-2014, 11:48 AM   #9
1320racer
1320racer's Avatar
possibly, but I know other racers that have had the same issues as well I've read the same on numerous forums from other racers in the years, since surmising that QC has gone down since they were bought out.
http://www.bobistheoilguy.com/forums...Number=2886948
Old 01-18-2014, 11:54 AM   #10
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Like anything else,I suppose it is possible to get a bad Optima Red battery,but I have had great luck with them over the years.
Even though they seem to last and last,I usually will buy a new one about every 3-4 years.
Optima even pays contingency.(they have for the last few years anyways)
