Old 02-08-2014, 05:27 PM   #1
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
Default Re: Is a Mexican Block Worth the Trouble?
If you have the money get the boss block it's alot better than the stock block..but I know a few SBF guys that are running the stock block with no issues in SS.. I would def put hard block in it. I have a Mexican block in my mustang and has run some 10.30s...with a stickshift at 7400rpms..
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 02-08-2014, 06:13 PM   #2
randy wilson
Liked 22 Times in 22 Posts
I don't know about filling a Ford block, but I've filled three GM 283, and 327, and 350 blocks in my life. I would NEVER fill a block. Every time we've done it, when you get ready to re-hone, the chatter from the stones going down in an oblong bore, is deafening. They NEVER stay round. On the other hand, when not using filler, the block was WAY straighter. And yes, we use a plate.
don,t have one
Old 02-08-2014, 06:32 PM   #3
BillK
Liked 30 Times in 17 Posts
Randy,
Curious as to what you filled the block with ? I had the same experience years ago with a block I did for a customer that he had filled. He used one brand of filler that I had never used and his block did move around a lot on the first freshen-up and a little bit the second time.
I have always used Hard Block and have never had it move around ?
Bill Koustenis
BillK is offline   Reply With Quote
Old 02-08-2014, 09:10 PM   #4
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
When filling I use Halco Machine Grout and leave the block sit for at least a month with the mains and both heads torqued, then I bore and hone. If you're in a hurry it becomes a compromise situation.
Paul Precht is online now   Reply With Quote
Old 02-08-2014, 10:43 PM   #5
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Got an email from this fella and it's still for sale. He says it was last bored 50 over. The NHRA limit is 80 over, so is this block weakened if it's a total of 60 over stock?
Dale
Dale Shearon
68 Mustang 6394
Old 02-08-2014, 11:21 PM   #6
HR9121
HR9121's Avatar
I ran a 302 Mexican block in my hr/sst car a couple years ago, it was 60 over and not filled. Made over 400 passes with never a problem and it turned 77-7800 when running 1/4 mile.
James Williamson
W200 J/SA. SS/JA
Old 02-08-2014, 11:22 PM   #7
Pat Cook
Is the Ford Motorsport block legal?
Part number M6010BOSS302K
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 02-08-2014, 11:49 PM   #8
FireSale
FireSale's Avatar
That's the interesting part. it's not a BOSS block. It's a 302 replacement block made in Mexico and used by Ford for a lot of warranty stuff. It's a little stronger that the stock 302 because it's a bit thicker and has beefier mains, they are still 2 bolt, though. Bore, stroke and deck height are stock equivalent 302. Just stronger.
It's still for sale and has only been bored out the 50 over. I'm going to look at it next week. It's a little more sane for me as a hobby racer on my first build.
And, yes, the 6010 is legal in SS.
Dale
Dale Shearon
68 Mustang 6394
Old 02-09-2014, 01:17 PM   #9
Dale
If it was standard I would probably use it if you have it..
As plentiful as the blocks are do not waste the money on a 50 over block...
Old 02-09-2014, 11:40 AM   #10
randy wilson
Bill, I think they used Hardbloc, but not sure. Been 10 years ago. There may very well be a way to do it right. I know lots of people swear by it, and some of them are hitters. I'm just giving my little bit of experience with it. On one .90 over 283, (I know that's a weird bore size) it never stopped moving around, even after 4 hones. It was an SS\CS 287, north of 600 HP with iron bowties.
don,t have one
