Liked 240 Times in 112 Posts
If your engine has either of these heads ... D1AE-GA, D0AE-N ...on it you could build the 71 330 hp motor. Big mechanical cam, almost 12:1 compression, yes the 780 carb, the ALTERNATE alum manifold that everybody but the Ford guy's dislike, proven screamer.
Dave Noll, EF/S ,?/SA 6526 |
Looks like if I go for the 324 (GT FACTOR) 351C I'm in GT/E or F...thats if I'm figuring right. still not 100% sure.
Not sure about the GT thing. The 324 HP motor has less compression & a smaller hyd. cam. All else the same. 16 rated HP difference between the 2. I like the looks of the 330/340 hp combo myself.
Liked 26 Times in 13 Posts
With the D1AE-GA heads you can only run it as a '71 351/285 factored at 324 for GT or 351/330 (the Boss 351 engine) factored at 340 for GT. The Boss engine can only be run with a stick. The Boss engine could have some advantages if it were running in stock, although I can't recall if anyone that has done it. In S/S the advantages are less since you are not restricted in cam/valvetrain or intake manifold so the only thing you lose is a little compression, almost certainly not worth the 16 HP factor difference . You can use the 780 Holley/Quickfuel carb on either.
The code on the block is irrelevant. If it is a Cleveland block, its good to go. If you go with the 351/285/324 these are the classes you can run (assuming by "Coupe" you are talking about a notch, not a fastback body). Click on the pix to make it larger/readable. GT/DA to GT/FA are likely your best bet depending on how much weight you can get out of it. 3078 lbs without driver is pretty light for a '69 Mustang.
Bill Harris ex 2172 STK ex 2272 S/S Last edited by Bill Harris; 02-08-2014 at 09:26 PM. Reason: f'ed up the math |
CRAP, Super Stock. Sorry. Started new medications today so I'm a little fuzzy.
Liked 35 Times in 11 Posts
SS/GT 69 mustang? I heard about this and was not sure if it was true! can you run an early body with a late year motor in SS/GT? like a 305 in a 1968 Camaro?
Most definitely. You could put an LS engine in a 68 Camaro if you wanted. Super Stock rules though, not Stock in NHRA. IHRA has a Stock GT class too but then you are limited to their events.
Bill Harris ex 2172 STK ex 2272 S/S |
thanks bill, that is awesome,can you use a buick,pontiac,olds motor as well in a chevy? super stock legal motors of course.
