Old 02-08-2014, 09:10 PM   #11
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Is a Mexican Block Worth the Trouble?
When filling I use Halco Machine Grout and leave the block sit for at least a month with the mains and both heads torqued, then I bore and hone. If you're in a hurry it becomes a compromise situation.
Old 02-08-2014, 10:43 PM   #12
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Got an email from this fella and it's still for sale. He says it was last bored 50 over. The NHRA limit is 80 over, so is this block weakened if it's a total of 60 over stock?
Dale
Dale Shearon
68 Mustang 6394
Old 02-08-2014, 11:21 PM   #13
HR9121
HR9121's Avatar
I ran a 302 Mexican block in my hr/sst car a couple years ago, it was 60 over and not filled. Made over 400 passes with never a problem and it turned 77-7800 when running 1/4 mile.
James Williamson
W200 J/SA. SS/JA
Old 02-08-2014, 11:22 PM   #14
Pat Cook
Is the Ford Motorsport block legal?
Part number M6010BOSS302K
67 Ford Fairlane
F/SA
749
Pat Cook is offline   Reply With Quote
Old 02-08-2014, 11:49 PM   #15
FireSale
FireSale's Avatar
That's the interesting part. it's not a BOSS block. It's a 302 replacement block made in Mexico and used by Ford for a lot of warranty stuff. It's a little stronger that the stock 302 because it's a bit thicker and has beefier mains, they are still 2 bolt, though. Bore, stroke and deck height are stock equivalent 302. Just stronger.
It's still for sale and has only been bored out the 50 over. I'm going to look at it next week. It's a little more sane for me as a hobby racer on my first build.
And, yes, the 6010 is legal in SS.
Dale
Dale Shearon
68 Mustang 6394
Old 02-08-2014, 11:59 PM   #16
Dyno
Dyno's Avatar
Liked 685 Times in 204 Posts
If it is .050 over already, save your money and try and find a standard bore block. He is selling it for a reason, usually not good.
Dyno is online now   Reply With Quote
Old 02-09-2014, 12:06 AM   #17
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
I read up on Mexican Blocks before using one in my street rod...(55 F100)....please understand that this engine is intended to "sound good" and I don't care how fast it it.....it is a 302.....I understand that the Mexican block is better because it has more nickel (SP) content....I don't know why that is better, it is just what I was told.....I never run the streetrod over 6,000 so this might not be a good example...no sleeves, no light weight parts....."It sounds really fast........but it isn't".....LOL (that is what street rods are supposed to do)
Old 02-09-2014, 12:34 AM   #18
SStockDart
SStockDart's Avatar
The Mexican block can be identified by, for example, C8AM stamped on the block (unlike the C8OE or C8AE). The M in the # is for the Mexican block. They have a higher nickle content for strength and wider main bearing caps. Buying a Ford racing block might be a better option. They are available for under $300 if you can't find the mexican block. They are fairly rare.
easy Id on a mexican block is the two large humps cast into the block, right below the heads. They only had a higher nickel content.
Many have the belief that Mexican means something sub-standard to US standards....that is not the case...These blocks meet the standards of Ford Motor Company or they would not use them....it is that simple.
Old 02-09-2014, 01:17 AM   #19
goinbroke2
Liked 393 Times in 153 Posts
.050 on a windsor? I'd be sonic checking the thrust side before I laid any coin down, I don't like over .030. they're thinwall castings.
goinbroke2 is online now   Reply With Quote
Old 02-09-2014, 01:58 AM   #20
Alex Denysenko
Alex Denysenko's Avatar
Liked 4 Times in 3 Posts
Originally Posted by FireSail View Post
Thanks for the quick replies. My car will probably be SSGT/L to M Auto, and I don't think I can get 9000 rpm out of my first racer. BOSS would be the way to go, but they cost a lot. I can get the Mexican for around $300.
Dale
Ford BOSS or Dart for SS MY stuff is north of 9500 on every pass I wouldn't waste my time or money on a taco block for a stocker much less a SS MOTOR, spend wisely and spend it once we built many nice reliable bracket motors out of Taco blocks I have been doing this a long time and have been using Ford Racing blocks since the A-4 Trans Am blocks became available in 1982 and still do if you want to make power from a little motor you need good ring seal, to get good ring seal you need a good block while better than a stock 289/302 unit, a filled Taco block will still never do the job that a aftermarket FRPP or Dart can..
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK
Moneymaker Racing LaPorte Indiana 219-861-1214
www.moneymakerracing.net
Alex Denysenko is offline   Reply With Quote
