#31 | |
Liked 184 Times in 113 Posts
http://www.tunercat.com/ Do you have a 93 or 95 LT1 Camaro? The Manual Valve Body most likely by passed the 1-2 Shift Issue. Using a Converter greater than 3000 Stall causes the Housing to twist a degree or two preventing the Reluctor to lose signal with the Pickup. Happens with Slicks and grippy surface. Under normal conditions and street tires you do not have that problem. Not an issue with ODB2. BTW 4200 Stall is about the limit on our engines. D |
