Liked 276 Times in 54 Posts
FS/A: Minimum weight 451 + CID 3200Lbs, index 10.10
FS/B: Minimum weight up to 400 CID 3250Lbs, 401 to 450 CID (including maximum allowable overbore) 3350 pounds, index 10.40 Any comments?
Been racing Stock and S/S cars since 1973. |
Liked 3,205 Times in 977 Posts
I just saw that's what the weights/indexes are for 2014 Factory Stock starting at Gainesville. So comments will come alright but the acid test will be who shows up...
Liked 325 Times in 50 Posts
We will pull the V10 cars out of the shootout. Just can't make up for the hair dryers. We will either run Stock or just not bring any stock ones to Gainesville. Actually what was proposed by SRAC was 9.95 and 10.20 indexes. And I proposed the V10 cars in the natural class @ 3500 lbs. up from 3350 for the V8 cars. Just shows how much pull I got. We will bring one v8 car I guess. Still a great idea, just needs some tweaking. I heard there would be a blown Toyota in the classes?
Jeff Teuton 4022 STK |
#4 | |
Liked 175 Times in 78 Posts
BTW we are the only cars effected by greater then 450 ci Ron
time is our most precious resource, you can always make more money but you can never make more time spend your time wisely with the ones you love - Ron Durham |
Liked 24 Times in 13 Posts
This should help clarify the difference in the rules for the new FS/A class. When Mike D made his original post the last sentence was left off the FS/A class rules. Here is the correct wording according to the NHRA web site:
FS/A: Minimum weight 451 + CID 3200 pounds, all supercharged 3500 pounds, index 10.10 FS/B: Minimum weight up to 400 CID 3250Lbs, 401 to 450 CID (including maximum allowable overbore) 3350 pounds, index 10.40 FS/A: It looks to me that what this boils down to is the new 2014 COPO Camaro 450 cu in F/I car (if overbored) now races in FS/A and receives a 300 lb. weight reduction (3200) over a 3500 lb. Supercharged car. Obviously Ford and Mopar are not going to submit a 450 cu in F/I engine (at least not this year) so NHRA had no choice but to throw the new GM 450 in to the lion's den with the Supercharged cars. The good news here is perhaps the fans will get a kick out of seeing a F/I COPO racing heads up against a Ford supercharged car? The bad news is will any COPO Camaro be able to get down to the 3200 lb minimum weight let alone get down the race track effectively on a 9 inch tire with 850+ HP?? We shall see.... FS/B looks unchanged from last years rules as long as the 450 or under cu in rule is adhered to. To me this is a good thing for last years cars still wishing to run the Showdown Cass. Let's face it, if the new GM 450 wasn't pitched in with the FS/A cars the 426 Hemi and the 427 COPO's wouldn't have stood a chance against them, so no way could they be allowed to run in FS/B. Another good thing here is that 2012 & 2013 COPO's won't have to convert their cars to the 2014 model and build new 450's to remain competitive in the class. Hopefully the balance of the Stock Eliminator entries will also be happy that both classes of Showdown Cars got a tenth whacked off their indexes and as a result won't dominate the Q sheet as much as last year at Indy. However, I'm sure there are those who feel that it still isn't enough.
Mike Keener A/S B/S C/SM Last edited by Mike Keener; 02-14-2014 at 12:58 AM. Reason: added copy |
Liked 10 Times in 6 Posts
Jeff Teuton Why don`t you put a 426 hemi in your 2009 challenger? Jim Harrison went 9.01 at indy open at 3320 BB/SA, F/SB 10.40 index 3350, that's only 20 more pounds 1.40 under. Tom
Tom Moock 5704 STK |
Tom, I have one 426 already, and might put the spare in another. We will be in Gainesville with at least one.
