I plan to use schumann low volume ,low pressure oïl pump in my chevy 350 SS/HA.The main bearing clearance are at .0029 +/1 .0001
. What oïl pressure I can expect?. Thank! |
Liked 1,898 Times in 426 Posts
So, you're running a -10% volume pump and what amounts to 0.003" on the mains? What is your clearance on the rods? What oil?
Alan Roehrich 212A G/S |
Sorry,you should read main bearing clearance are at .0029 +/- .0001. The rod clearance are at .0026. +/- .0001. The rod side clearance are at .014. 15W 40 oïl .
Thank! |
That's a lot of oil clearance for a low volume pump, isn't it?
Which rod journals?
Ed Wright 4156 SS/JA |
rod journal are at 2.0995
Liked 18 Times in 10 Posts
#7 | |
Too much clearance for a -10% volume pump. And 15W40 is not really a good oil choice, either. You'll have about 10 psi hot at an idle of 800 RPM. And maybe 50 psi at 6000-7000 RPM.
Block is dart shp pro block, Crank is Gm 1184, rod are crower ml 93005.
#9 | |
Liked 99 Times in 49 Posts
